Author Topic: 71" (1.8m) TID Tug Build (Cont'd!)  (Read 5997 times)
tizdaz
  • Boom!
« on: October 29, 2021, 02:19:42 am »
Hi guys,
I Decided to start a new thread for my build as my previous thread have broken links to all the images :(
...sooo to kick it off, My electric board is pretty much done, but I'm going to be adding a P103 Parallel Power Board to bump up the capacity for longer run times.
Here's a few pics, I've done a dry test & connected everything up & ran it as I would for a good 40+ mins constant, everything seems good (touch wood!) the 2 step up converters barely get warm which is a bonus! will add some vid tommoz, I have to say, the BIER sound module is a top notch piece of kit, its a lot more than just a sound module! ..takes a little getting to grips with the software as there's hundreds of options for lights/fans/sounds etc!
Will take some vid tommoz, I'm pretty happy with the outcome, took a while to complete but worth it i think, Next on the agenda is to complete my second take on the stack (my 1st attempt was good, but the stack was slightly too large! so i made a start on a new one.
Wiring Diagram:
Test #1
Completed
My large-scale TID Build Website: http://www.tizdaz.co.uk/forum
Facebook:
BrianB6
Re: 71" (1.8m) TID Tug Build (Cont'd!)
« Reply #1 on: October 29, 2021, 06:30:55 am »
Nothing beats Perspex for mounting electronics.  O0
tizdaz
  • Boom!
« Reply #2 on: October 29, 2021, 06:55:02 am »
indeed!
the perspex i used was clear, so gave it a coat of black from the underside, did the trick! :)
Facebook:
« Reply #3 on: October 29, 2021, 10:00:37 am »
Oh yes it does, Paxolin (Tufnol - SRBP or F) isn't subject to static charges.
tizdaz
  • Boom!
« Reply #4 on: November 01, 2021, 02:52:12 am »
Wheel almost done, made from scratch using wood & some thin brass rod, gave it a coat of stain/varnish going to give a couple of more coats & tidy it up with a little sanding :)
Last pic has an AA battery in view for size comparison,
Facebook:
tizdaz
  • Boom!
« Reply #5 on: November 14, 2021, 10:42:19 pm »
Electric Board/Box complete :)
Finally finished my electric box :D
i made this box using bits of ply & Perspex, I also decided to fit a 12v fan to the case that i had laying around to help keep the temperature inside the case low. The fan is connected to the Beier USM-RC2 module & I have programmed the module so the case fan operates at 60% & it will also automatically switch off if there has been no signal from the TX after 1 min. It will automatically turn on again as soon as there is a signal again from the TX (Such as forward on throttle or light switch etc). I decided to use pluggable terminal blocks, these are pretty neat & will allow me to insert/remove the electric box with ease :) The two servo extension wires you see are for the Rudder servo lead & the main power switch which i will be fitting somewhere above deck but hidden for easy access to turn the model on/off, I will probably fit the power switch under one of the engine room hatches.
Next the Agenda, is to cover the deck with some filler & also some UPOL Dolphin Glaze as recommended to me by someone in the know! & get it ready for painting along with the hull.
Facebook:
tizdaz
  • Boom!
Re: 71" (1.8m) TID Tug Build (Cont'd!) (Updated: Electric Box Complete!).
« Reply #6 on: November 14, 2021, 10:55:05 pm »
oh yeh, also heres new diagram as ive added a P103 and made a few other tweaks etc!
Facebook:
TheLongBuild
  • Build em, and play hard..
« Reply #7 on: November 15, 2021, 08:25:21 am »
That's a flipping micro pc  %% %% %%
« Reply #8 on: November 15, 2021, 08:25:30 am »
             Impressive design, implementation!    :o
tizdaz
  • Boom!
« Reply #9 on: November 15, 2021, 09:10:54 am »
lol cheers guys :)
when it comes to electrics/wiring i have OCD i think! even though i will very rarely see it as its tucked under the deck, i still want it to be neat & tidy lol :D
Facebook:
TheLongBuild
« Reply #10 on: November 15, 2021, 11:13:48 am »
Like the self destruct plunger on the top.. :}
tizdaz
  • Boom!
« Reply #11 on: November 15, 2021, 05:22:23 pm »
i actually felt like self destructing at times while trying to make it! lol
Facebook:
« Reply #12 on: November 15, 2021, 07:08:48 pm »
Why two BUCK 24v converters?
NB: If you still have the images from the previous thread Daz, I'll happily re-add them for you.  :-))
       https://www.modelboatmayhem.co.uk/forum/index.php/topic,56353.0.html
tizdaz
  • Boom!
« Reply #13 on: November 15, 2021, 07:26:50 pm »
NB: If you still have the images from the previous thread Derek, I'll happily re-add them for you.  :-))
im using 2x mist units so decided to use 1 converter for each mister :)
Facebook:
« Reply #14 on: November 16, 2021, 12:56:11 am »
....'images from the previous thread Derek'....
do you mean DAZ.... Martin?
tizdaz
  • Boom!
« Reply #15 on: November 16, 2021, 01:00:40 am »
i do have them, but no idea what ones are missing from which post etc & i have lots (100's) of images :(
Facebook:
tizdaz
  • Boom!
« Reply #16 on: November 16, 2021, 01:01:06 am »
Facebook:
tizdaz
  • Boom!
« Reply #17 on: November 22, 2021, 12:45:58 pm »
Deck is now fixed in place & added the coaming, the coaming was fixed in place by screws & also some Titebond III wood glue. The coaming will be covered in Body filler/dolphin glaze when i do the deck to give it a nice finish & watertight seal.
so she's now ready for the deck to be filled using this stuff:
Big Boy Ultra Fine Body Filler
& then i will use this to finish off:
I also fit some Ferrules to my cable ends for the pluggable terminal blocks, I bought the tool from Ebay, and have to say it works perfectly, i tested out the fit by trying to pull the ferrule off with force using a pair of pliers, no chance! it was well & truly fixed on, the crimp tool kit cost just over £14 and that was with 1200 connectors of various sizes (AWG 10 through to AWG22) delivered!
So next will be filling the deck & finishing it off so i can then get on with the Superstructure build! :)
Facebook:
tizdaz
  • Boom!
« Reply #18 on: November 22, 2021, 01:05:30 pm »
Finished the new stack!
The old one was slightly too big so i remade it & now its exactly true to scale, i just need to complete the top/bottom of it & the details etc!
The one on the left is the OLD one compared to the new one on the right side :)
They were both made using planking & some plumbing tube for the centre with wooden/plastic discs as spacers.
Facebook:
tizdaz
  • Boom!
« Reply #19 on: December 16, 2021, 01:05:25 am »
righty!
So I've almost complete new stack, just got to finish off the top of it & then paint it, the colours will be green body with a dark/racing green top section to match what the hull green colour will be.
I've also added a couple of shelves at bottom of hull to place the ballast tubs, just need to add a couple more shelves to the forward & aft of the hull. I'm hoping (if my calculations are correct!!) that the ballast tubs which will total 25kg & then the 4 SLA's which total 25kg along with the superstructure/electric board and all the other bits & pieces etc that this will be more than enough to ballast her :)
Ballast Shelving:
Facebook:
tizdaz
  • Boom!
« Reply #20 on: December 16, 2021, 01:09:12 am »
for some reason images when i post them are sometimes loading & other times they are not!?
just happens randomly what images the page will load?
Facebook:
tizdaz
  • Boom!
« Reply #22 on: January 13, 2022, 01:51:33 am »
filled deck using Big Boy Ultra Fine 2-Part filler & then a thin coat of U-Pol Dolphin Glaze, Yes my filling skills are not great, but end result I'm happy with and deck feels solid. Once Bulwark supports are all in place i will then be using some high build primer to cover the whole bulwark area & supports.
I also trimmed the top of bulwark edge to give equal width right the way around.
Making a start on the Bulwark supports now, at first i was going to use 5mm ply but someone mentioned that 3mm would be more scale so im using 3mm ply now! It's a VERY time consuming process as every support has a slightly different shape so using a template to make all of them isn't possible. I still need to make about another 30!
After the Bulwark supports are completed i will then fix them in place then i will make a start on the deck planking :)
Facebook:
nemesis
« Reply #23 on: January 13, 2022, 03:13:27 pm »
dont forget to cut the corner off the stay, deck to bulwark. lets the water run through. nemesis
Ralph
« Reply #24 on: January 13, 2022, 09:46:32 pm »
Makes the supports easier to shape and fit as well since you don't need to worry about matching any fillet between the deck and bulwark.
Ralph
Page created in 0.088 seconds with 22 queries.
