loose as in a bean bag seat or solid as in the packaging you get with the washing machine etc, neither will absorb water (well not strictly true the solid does absorb water but between the beads and to a greater extent in the loose as they are not compressed together) a single bead will not absorb a noticable amount - as it breaks down however then yes, if contained in a plastic bag then the likely hood is moisture from the air.
