Author Topic: 46inch RAF crash tender  (Read 2007 times)
Mach1
« on: November 13, 2021, 06:57:39 pm »
I have just obtained a completed model of the 46 inch RAF crash tender which was driven by a single electric motor. I am keen to alter this model to be powered by two electric motors. I already have two spare motors that I would like to install, they are Multiplex Roxy BI Outrunners C42-50-06 Brushless Motors 800KV.  I will also have two speed controllers, ZTW Seal 130A SBEC Marine ESC (2-6 Cells). I would greatly appreciate any members advice about my idea.
madwelshman
  • Learning all the time.
  • Fairey Marine Fanatic
Re: 46inch RAF crash tender
« Reply #1 on: November 15, 2021, 03:46:53 pm »
Yes, you could use those two and just not run them anywhere near full potential, as I would have thought that will be way more than enough power for that size of model.
In fact, just one of those motors would probably be enough on it's own, let alone two of them.
I would say that a pair of 35mm outrunners of around 1000kv would be somewhere near right for that and can be picked up cheaply enough (Around £18-28 each).
Will
49" Precedent Perkasa
46" Aerokits Sea Queen
42" Veron Fairey Huntsman 28 x2
34" Lesro Sportsman mk1
34" Precedent Fairey Huntsman 31 x3
34" Aerokits Sea Commander x2
29" Aerokits Sea Rover
20" Aerokits Fast Patrol Boat
16" Aerokits Sea Urchin
Mach1
« Reply #2 on: November 15, 2021, 04:35:22 pm »
Thank you for your advice, and yes it does seem that with two of these motors it will be overpowered.
Dave_S.
  • Member of Oxford Model Boat Club
« Reply #3 on: November 15, 2021, 05:45:46 pm »
I bought a second-hand 46" Crash tender recently, it came fitted with a single brushed motor. I am planning to change that for a brushless 4258 500kv running on 16 NiMH or 6S Lipo. I prefer the NiMH option as I object to paying for expensive Lipos only to have to add ballast.
Once I get my bench back up and running, the engine swap will only take a day or two, so I am hoping to get it on the water before the end of the year.
Ruining perfectly good kits since 1969.
Mach1
« Reply #4 on: November 15, 2021, 06:14:27 pm »
Good luck with your motor swap. I really should have just stuck to one motor rather than two. I will have to go easy on the throttle.
Dave_S.
« Reply #5 on: November 15, 2021, 06:18:37 pm »
I'll let you know how it goes with the single outrunner, twin motors are more fun, though. I have a Robbe police boat with two and have them mixed so I can rotate on the spot at low speed and back up to a mooring point - adds to the interest of operating. If I was building the Crash Tender I'd probably use two motors, but the one I bought was a just a quick and easy way to get on the water, so I don't want to do anything too radical to it.
ChrisF
  • What's my favourite cake!
« Reply #6 on: November 15, 2021, 06:24:56 pm »
I don't think that two motors will affect top speed much, more the acceleration, so as you say easy on the throttle!
And if your transmitter supports it adjust the throttle for a gentler curve.
Building Fairey Marine boats: River Cruiser 23 prototype, Huntress 23 Long Cabin with stern-drive, Huntsman 28, Huntsman 31 and Swordsman 33 and two more to come! All scratch built and to a scale of 1:12
canabus
« Reply #7 on: November 16, 2021, 05:36:15 am »
Hi All
I am using a Scorpion S4020-450kv (1850Watts) on 6S Lipo (12150rpm) with a 120Amp ESC and a 52mm 2 blade CNC prop.
At 80% throttle scale speed with plenty of power left.
Used twin 3S 4500mah batteries (in series) and mounted each side of the rudder to get the boat to plane and turn right.
Canabus
Dave_S.
« Reply #8 on: November 16, 2021, 07:42:40 am »
Very similar to my set-up (not yet installed) - how many amps are you drawing at full throttle with this?
Not quite sure where your revs are coming from, 450 kv on 6s Lipo should be just under 10,000 RPM maximum, less in practice.
(I'll get those Waverider plans sorted out soon!)
canabus
« Reply #9 on: November 16, 2021, 10:07:05 am »
Hi Dave
the rpm should be 10150, but just got a new pair of Nanotech Lipo batteries which are 15.2 volts !!!
Canabus
« Reply #10 on: November 16, 2021, 10:29:17 am »
" I am keen to alter this model to be powered by two electric motors. "
  Why? Is it going to be a shelf queen.  Would be inclined to thrash it about before damaging the hull.
Mach1
« Reply #11 on: November 16, 2021, 12:39:30 pm »
Thank you all for your advice and shared experience with one or two motors.  I am pressing on with my two motor installation and will report on the performance. The throttle curve idea sounds a good plan.
red181
« Reply #12 on: January 03, 2022, 11:47:53 pm »
have a read of this build I did a number of years ago :-))
https://www.modelboatmayhem.co.uk/forum/index.php/topic,39278.0.html
Mach1
« Reply #13 on: January 05, 2022, 07:39:31 pm »
Thanks red 181.  A very detailed and interesting read.
DHutch
« Reply #14 on: April 02, 2024, 03:29:20 pm »
Any chance of an update?
Dave_S.
« Reply #15 on: April 02, 2024, 04:29:17 pm »
There was a 46" Crash Tender on the water at the Oxford Model Boat Club a couple of days ago, performed very well on a pair of 2836 1000kv out runners, on 3S Lipo packs. Certainly didn't lack power, and by using a mix in the transmitter the owner was able to manoeuvre the model very accurately.
I was surprised at how well it went on such small motors, but the proof was on the water. No shortage of running time, either.
Page created in 0.093 seconds with 22 queries.
