Pretty sure JimG hit the nail on the head here with BogStandard ball bearings being manufactured to ISO, BS or Din Standards by their millions and to the diametrical tolerances permitted
The only time Model Engineers will [generally] find extended range sizes would be eg.,
matched pair of angular contact or Roller Bearings for the headstock of their Myford lathe
......[but you may need an appointment with the Bank Manager to secure a $$$$ overdraft]
These are manufactured and matched as pairs to very small portions of uM's [Microns'] which most could not see let alone measure
One would suspect if a sealed ball bearing, was either tight or sloppy in a pressure injection cast plastic housing, it is the housing that will be the cause of the questionable Class of fit Maybe the only thing original with
Brand Name bearings, is the cardboard box, or plastic bag they are supplied in
