Author Topic: Build number 10 of the year - Aeromarine Conquest 44  (Read 1309 times)
Andyn
« on: November 19, 2021, 11:24:15 am »
After a brief break to play with some robotics I've completed another build, this one is an Aeromarine Conquest 44.
Power for this is an RCMK 254 evo, with a Chinese pipe. Came across the engine in a swap, the hull was only £50 second hand (unstarted) and most of the other bits I already had, so this thing has cost me less than £150 to build.
The holes in the hatch look a little odd as it's a bit of a poorly designed hull, others have found that in order to get it to not blow over it requires the engine being as far forward as possible. I managed to get the RCMK extremely far forward, which has created the need for a cutout in the lid for both the exhaust header and carb, the latter needing a carbon splash sheild adding to avoid any water ingress to the engine.
Waiting on a couple of finishing touches in the post - water fittings, receiver and a better exhaust bracket, then it'll be off to the lake for testing. Engine is already run in and set up so it'll hopefully just be a case of putting the right prop on it.
Re: Build number 10 of the year - Aeromarine Conquest 44
« Reply #1 on: November 19, 2021, 05:47:54 pm »
Nice one Andy  :-))
Andyn
« Reply #2 on: February 06, 2022, 06:51:32 pm »
Took the Conquest out for its first run today, didn't go too badly at all :-))
https://youtu.be/Y-6KJBCCFPY
« Reply #3 on: February 06, 2022, 07:54:42 pm »
Brilliant, are you using sub drive of surface piercing Andy
Andyn
« Reply #4 on: February 06, 2022, 09:35:08 pm »
Surface prop mate, shaft is in line with the bottom of the sponsons  :-))
« Reply #5 on: February 06, 2022, 10:19:30 pm »
Flex shaft I guess, bringing it to MAYEHM I hope :}
Andyn
« Reply #6 on: February 07, 2022, 09:17:07 am »
Yep I've got flex shafts in pretty much everything, all from Mark Copley.
Undecided yet what I'm bringing to Wicksteed but it's likely to be 5-6 boats. Richard and I are planning to have a very large setup
« Reply #7 on: February 07, 2022, 08:58:47 pm »
Are you bringing some loopy juice fuel as well, cos I'll put it into my straight runner......and you catch it  :-)) :-)) :-)) :-))
Andyn
« Reply #8 on: February 08, 2022, 08:37:04 am »
I can certainly bring you some fuel, have you got a starter belt in it yet?
Andyn
« Reply #9 on: June 05, 2022, 07:42:04 pm »
Took it out again today for a run, is really getting somewhere now :-))
https://youtu.be/v7504i2_QG0
Page created in 0.095 seconds with 22 queries.
