Technical, Techniques, Hints, and Tips > Glue etc.
UV curing clear resin for glazing portholes.
tonyH:
Hi All and many thanks for the input.
The ones I want to glaze are sealed from the back and what I'm after is, effectively, a crystal clear,self-hardening, varnish that will not soften at a thickness of about 2mm. I don't think that the glue and glaze type will harden fully unless I use loads of layers so I reckon the UV stuff is worth a go.I'll get a torch John, they've got other pet-orientated uses. They're cheap enough as long as the job doesn't need the wattage of a tanning booth. I can then report back if anyone is interested?
Tony :-))
colin-d:
I used glue and glaze on all my portholes... small or large..
Navigation
[0] Message Index
[*] Previous page
Go to full version
