Pages: 1 2 3 4 [5] 6 7 8 9   Go Down
Author Topic: Scanned Old Model Boat Magazines  (Read 79142 times)
Re: Scanning Old Model Boat Magazines
« Reply #100 on: December 30, 2021, 01:43:49 pm »
Model Boats, June 1978
MPBA, Jim King - New scale competition
Northern Festival, Pontins
Oliver Lee model racing yacht fittings
J B Mouldings, Wales
Radio-Active models, Hornchurch
John Piper collection, Corvette Kit, 1:96
Swan-Morton knives
« Reply #101 on: December 30, 2021, 10:00:15 pm »
Norsk SH, Christian Radich - Martine Scale kits
Conway Maritime Books
Cyanolit Superglue, Tivoll Kay Adhesives
Robbe
North Wales Craft Festival
Cleethorpes Model Boat Bonanza
Veron, Pilot Launch, Titan Tug, Vosper RTTL, Tarpon
« Reply #102 on: December 31, 2021, 01:17:27 pm »
Model Boats, July 1976
Some ideas for Model Submarines by P Jeffery
Vosper 73ft High Speed Launch by John Pritchard
« Reply #103 on: January 01, 2022, 04:21:20 pm »
Model Boats, August 1971
Front cover,
Index page
Rear cover
« Reply #104 on: January 01, 2022, 04:37:30 pm »
Beatties of London .... and Manchester
Ripmax electric motors ( Hectoperm Special £5.39 !!! )
Model railway Exhibition, central Hall, London W1
Dave_S.
« Reply #105 on: January 01, 2022, 05:25:53 pm »
I remember buying that one from the local newsagents - seeing that cover brings back a flood of memories.
« Reply #106 on: January 05, 2022, 10:05:00 am »
Electric Scene, Philip Connolly
Pedalo E. F. Amiss
Royal Albert, Richard Walker
« Reply #107 on: January 05, 2022, 10:14:04 am »
Northwestern  Miller
Helgoland
« Reply #108 on: January 06, 2022, 12:15:00 pm »
 Electric motor control,  A H Ithell
 Racing model yacht construction, R C Giffin
 1970 36in Restricted Championship, June, Borneville
 R/C Yachting in the USA
« Reply #109 on: January 07, 2022, 07:12:04 pm »
Model Boats, August 1974
« Reply #110 on: January 07, 2022, 07:19:51 pm »
Lightfoot 57in 'A' class yacht, G. K. Collyer
IC engine silencers
Thornycroft MTB, J Gore
« Reply #111 on: January 07, 2022, 07:23:20 pm »
Deep Sea Towage, P N Thomas
Japanese Steam Engines, J F Edgar
Re: Scanned Old Model Boat Magazines
« Reply #112 on: January 08, 2022, 08:43:32 pm »
Model Boats, October 1975
Index page
HGH Models, Royal Sovereign
SHG Marine, Propeller shafts  / drive train
Nor-Star, Wave Crest, Crash Tender
Keil Kraft fittings
MRH Eastbourne, Multi boats
« Reply #113 on: January 08, 2022, 11:12:51 pm »
Model Boats, June 1977
Index page
« Reply #114 on: January 08, 2022, 11:19:02 pm »
Take Five. Five model ships, ( the Great! ) Robert A Wilson
Plywood Hull Drafting, R Cardoso
Krispie 36in yacht, ( also highly very acclaimed! ) Vic Smeed
Freelance Cruise yacht, N hodgson
kinmel
« Reply #115 on: January 10, 2022, 04:40:28 pm »
From Model Boats November 1965, I am not sure I could have sorted this out into cutting patterns.....
The upload has been rotated and squashed, not sure how to correct that
« Reply #116 on: January 10, 2022, 05:20:42 pm »
The Forum software is not very good at handling modern digital images,  ( anything post 1975! )      {-)
kinmel
« Reply #117 on: January 10, 2022, 06:17:11 pm »
Thanks for fixing it  :-))
« Reply #118 on: January 10, 2022, 11:13:11 pm »
there you go kinmel ...also for all MBM Members standing up-side-down below the Equator Longditudes  :P  ....Derek
kinmel
« Reply #119 on: January 10, 2022, 11:26:13 pm »
Thanks Derek, but you forgot to convert the post's text....
]ʇɐɥʇ ʇɔǝɹɹoɔ oʇ ʍoɥ ǝɹns ʇou 'pǝɥsɐnbs puɐ pǝʇɐʇoɹ uǝǝq sɐɥ pɐoldn ǝɥʇ˙˙˙˙˙suɹǝʇʇɐd ƃuıʇʇnɔ oʇuı ʇno sıɥʇ pǝʇɹos ǝʌɐɥ plnoɔ ı ǝɹns ʇou ɯɐ ı '5691 ɹǝqɯǝʌou sʇɐoq lǝpoɯ ɯoɹɟ
I have just turned the page and found more instructions, please correct it if necessary - Thanks
sʞuɐɥʇ - ʎɹɐssǝɔǝu ɟı ʇı ʇɔǝɹɹoɔ ǝsɐǝld 'suoıʇɔnɹʇsuı ǝɹoɯ punoɟ puɐ ǝƃɐd ǝɥʇ pǝuɹnʇ ʇsnɾ ǝʌɐɥ ı
« Reply #120 on: January 10, 2022, 11:33:44 pm »
You're right, what a nightmare plan by todays standards!
Can you scan the rest of that article please, Kinmel ?   :-)
A couple of things I'd like to read up on;
 battery above prop shaft,
 battery recommended,
 coupling type,
 controller type,
 radio,
 Martin
« Reply #121 on: January 10, 2022, 11:39:20 pm »
Ha! Would you believe it.... https://www.ebay.com/itm/324273108540
kinmel
« Reply #122 on: January 10, 2022, 11:57:40 pm »
That is a coincidence !
You ask for more reading
 coupling type,
 controller type,
 radio,
I hate to disappoint you, R.A. Sweet did not specify them; there was probably only one option available then, maybe no option at all !
Below is the rest of his article, these 3 photos show all the information provided for the build.
Kevin.Hutch
« Reply #123 on: January 11, 2022, 06:09:14 am »
One of the critical issues in photocopying is to either use a flat bed scanner or you can almost guarantee to get a "keystone" effect where the picture forms a perspective view and this is very hard to correct as it is not just the top vs the bottom lengths but also the left and right heights.
It requires many accurate measurements to skew the picture back to the right aspect ratio and then accurate scaling to get it back to a useful proportion. Attached is the best I can do without accurate measurements to correct it properly actual of scale waterline length, centreline length beam and any other would allow a more proportioned rendition.
Kevin Hutch
Be part of the solution not part of the problem
Kevin.Hutch
« Reply #124 on: January 11, 2022, 06:14:33 am »
Even then I chopped off the keel, just required more attention. >>:-(
A little research found https://www.rcgroups.com/forums/showatt.php?attachmentid=3996… a good scan of the 1965 article.
As long as it did not infringe a copyright, I would be pleased to trace the drawings into a usable set of build drawings, if anyone is interested.
Kevin Hutch
Pages: 1 2 3 4 [5] 6 7 8 9   Go Up
Page created in 0.036 seconds with 21 queries.
