Author Topic: Brazing question  (Read 3226 times)
Klunk
Brazing question
« on: December 29, 2021, 08:14:23 am »
Ok have taken the plunge and bought a microtorch that will heat upto 1300 degrees.
I want to make a home made rudder.
1mm sheet brass and 2mm rod.
Whats the best flux and solder???
Ps have made jig to hold parts.
full time penguin
Re: Brazing question
« Reply #1 on: December 29, 2021, 09:16:12 am »
When I did mine for my Lindberg trawler many years ago, I sat both items on a bed of fireclay, and used soft cored solder.  And an iron with a big tip.  Nobody told me it couldn't work and wouldn't last.  "Many" is late 1980's.  Painting over it afterwards probably helped.
https://www.modelboatmayhem.co.uk/forum/index.php/topic,66323.0.html  might be helpful if really determined to go the silver solder route.
« Reply #2 on: December 29, 2021, 11:05:47 am »
Hi Klunk........ spend as much time as necessary viewing the tutorials on-line with Cup-Alloys......Derek
https://www.cupalloys.co.uk/for-model-engineers
Jerry C
« Reply #3 on: December 29, 2021, 11:12:28 am »
Two sheets 1mm brass for rudder blade. All soft soldered using jigs and small torch.
Jerry C.
Jerry C
« Reply #4 on: December 29, 2021, 11:21:53 am »
I forgot, cleaned everything with wire wool, applied Bakers Flux and laid solder strips then ran everything together with pencil torch.
Jerry C.
« Reply #5 on: December 29, 2021, 11:38:55 am »
I got this one Klunk.... never used it!
nemesis
« Reply #6 on: December 29, 2021, 11:52:30 am »
It is fine having all those degrees, it is the volume of heat you require. nemesis
Mark T
« Reply #7 on: December 29, 2021, 06:01:51 pm »
Jerry C.
I was just about to say the same thing Jerry - no need for anything other than soft solder and most importantly nice clean parts with a decent flux.  Nice job by the way :)
john44
« Reply #8 on: December 30, 2021, 08:07:40 pm »
Hi Pete, I agree, on that type of job soft soldering is plenty good enough.
For a stronger joint I use plumbers solder and flux.
« Reply #9 on: December 31, 2021, 06:47:56 pm »
Pete, I agree with Derek, check out cup alloys, their web site is very useful...
whatever you do, remember the golden rule, heat the material not the rod.... :-))
Page created in 0.055 seconds with 21 queries.
