I think in conclusion, when I first said....."the gear appears to be fixed and not able to be dis-engaged" ....was clearly 'incorrect'
Obviously the Designers and Builders some ~~120 years ago, realised when the engine Baring Gear was finished with, had two choices
1. the eccentrically bored Baring Worm + shaft + key + ratchet etc, were simply to be removed and packed away until required again
or
2. the Baring Worm rotated eccentrically + keyed out to provide a positive disengagement to the Worm Wheel, and the ratchet stored away
If the engine was used in a marine application [with the seawater condenser] the decision in the alternate storage of the Baring Gear would have been that of the Chief Engineer, who would I suggest inspect the Baring Gear orientation in his Check List, prior to starting of the engine
[There certainly could be arguments for either option]
I too initially, was looking for something that was not there. Would engine Turning Gear be designed on similar lines today?, probably not
