Pages: 1 2 [3] 4   Go Down
Author Topic: Which 3D printer to buy...?  (Read 24028 times)
Waiting2Retire
Re: Which 3D printer to buy...?
« Reply #50 on: September 13, 2023, 10:50:26 pm »
The printer will come with a model on the SD card ready to test it (used to be a cat of some sort for creality) and a small roll of test filament that will get you going. No need for computer for test print select the model on the printer display. Start basic and work up.
I find white and black most practical filament choices to start with, lots of makes and opinions, I never had any issues with the popular makes or even Amazon basics works well for me.
Keep opened filament in a bag with the silica gel it came with, most good rolls come in a resealable bag and with the gel.
The filament dryer is useful, but walk before you run it’s another complication start basic.
And JohnG - you’re not supposed to agree with people on the internet are you?  ok2
Also using Cura slicer, prusa one is supposed to be good too but better the devil you know for me with Cura these days.
« Reply #51 on: September 23, 2023, 02:21:25 pm »
1st Print in progress ....
     https://youtu.be/zv_bZ7StMLU
« Reply #52 on: September 23, 2023, 05:27:30 pm »
Well it finished! It didn't blow-up, burn the house down, print miles of spaghetti!
What do you guys think? Observations? Comments/ Advice?
Umi_Ryuzuki
    • Models and Miniatures
« Reply #53 on: September 23, 2023, 05:47:10 pm »
Note how you can scale in the slicing software before saving the gCode.
So you can print the same file in different sizes.
 Now maybe one of these...  :-)
  https://www.rcgroups.com/forums/showthread.php?3108381-For-Those-of-you-with-3d-printers-Boat-Files
Subculture
    • Dive-in to Model submarines
« Reply #54 on: September 23, 2023, 07:22:50 pm »
Print looks a bit stringy. What material, slicer/profile have you used?
« Reply #55 on: September 23, 2023, 07:33:21 pm »
TheLongBuild
  • Build em, and play hard..
« Reply #56 on: September 23, 2023, 07:43:30 pm »
Subculture
« Reply #57 on: September 23, 2023, 07:45:52 pm »
What slicer are you using. Cura?
« Reply #58 on: September 23, 2023, 08:39:49 pm »
Might have trouble in getting even two channel RC into that Martin!
« Reply #59 on: September 23, 2023, 09:06:03 pm »
« Reply #60 on: September 23, 2023, 09:09:31 pm »
Creality Slicer: "Creality Slicer is indeed based on Cura, but it's optimized for Creality printers."
I'm using it as it has the embedded config / profile or this printer, not many others have this printer yet....
« Reply #61 on: September 23, 2023, 09:40:55 pm »
I must confess that I am conflicted about 3D printing on a personal basis. I do find it interesting in many ways for producing fittings and components and some of the professionally produced items such as warship fittings are just amazing in their degree of detail and would be difficult if not impossible to reproduce using traditional scratch building methods. I can fully understand why modellers choose to go down this route.
But at the moment I am building a traditional Greek Fishing boat using conventional modelling techniques with plank on frame, lots of rubbing down and use of filler. Having been much involved with computers before I retired it's just nice to use wood, glue, abrasive paper and constructional techniques which mimic the full size vessel. It's all 'organic' with no plastic, nylon or petrochemical materials involved. The hull is partially covered with gumstrip paper even!
I suppose it is literally what floats your boat really! There is room for everyone in the hobby.
grendel
« Reply #62 on: September 24, 2023, 08:56:32 am »
to my way of thinking, a 3d printer is just another tool (a very versatile tool, but not the be all and end all of tools), so when i have something that cant be scratch built easily, then the 3d printer comes into use, and its generally for fittings and fixings that i use it, some I will take the time and effort needed to make them in brass on the lathe or mill, but others can more easily be made on the 3d printer, I actually enjoy both processes, as since I am a draughtsman, I get similar satisfaction in producing a 3d drawing of the part required for the printer that I do in machining the part on the lathe and mill, at the end of the day sometimes it comes down to whether I want the part in brass or plastic.
Waiting2Retire
« Reply #63 on: September 25, 2023, 12:04:30 pm »
The stringing at the top could be temperature related, what are you using to print at?
You can get test prints on thingiverse where it changes the temperature up a tower (using the G-Code) so you can see which ones are stringy, usually to hot, and adjust as needed.
Each filament brand seems to have a different sweet spot.
JaS
« Reply #64 on: September 29, 2023, 07:47:15 pm »
I had mine Artillery X2 for a week now and im very happy with it especially the bed size and the auto leveling function, for almost a week since I got it has been working and also the price was good.
Jack
« Reply #65 on: October 15, 2023, 02:17:53 am »
I've been mucking about with 3D printer a little bit now.... actually useful project .... this one didn't quite work,
 resigned the tolerances, reprinting now....
Last week's project, video light holder:
« Reply #66 on: October 15, 2023, 03:10:25 am »
Not too bad!
« Reply #67 on: October 22, 2023, 12:06:13 pm »
More Testing ....
Barney Magrew
« Reply #68 on: October 22, 2023, 02:44:33 pm »
I use a Creality CR6SE with Cura slicer and running through a Raspberry Pi, Obicom and C720 Camera.  Filament is Esun PLA+.   I've done more with this printer than any other.   It has heated bed and auto levelling.   Only downside is the size of the bed, but then, what do you want to print?
« Reply #69 on: October 22, 2023, 10:56:35 pm »
After much tinkering! ....
grendel
« Reply #70 on: October 23, 2023, 06:34:37 am »
I am currently printing a battery box to convert my makita 12v drill battery (old style) from NiMH to 18650 lithium cells.
« Reply #71 on: June 16, 2024, 04:55:22 pm »
Needed a 'grappling' / throwing hook, for boat retrieval, so dusted off my 3D printer.
I was pleased it still worked as expected, even though I had parked it in a bay window.... thus annealing it for once a day for 9 months!
First time using TPU material, it's a soft shiny plastic, like a cheap toy car tyre / grip on a garden tool / dog chew toy.
It's very stringy and needs extra thought as how to print it.
Left is the first, one piece attempt .... after I gave it a vigorous shave & a haircut!
Right it the redesign, 5 separate pieces, printed one at a time.
..... must get a retrieval Tug working again.
« Reply #72 on: June 16, 2024, 05:11:15 pm »
Also printed some Fender tyres for the 686 mini Tugs.
The round bow proved tricky for pushing stuff around....
MikeMcP
« Reply #73 on: June 16, 2024, 06:03:42 pm »
my 2p worth
I've been using a Creality Ender 3 for a couple of years now
upgraded it with
- BLTouch Z-axis sensor (worth its weight in gold)
- glass plate
- 3D printed spool holder
- direct drive filament feed
- metal bed adjusters
the last two make bed-levelling easy and allows the printer to compensate for a non-flat/level bed
I slice with Cura
and the best thing of all
- OctoPrint - amazing bit of software - allows you to upload files via WiFi and control the printer the same way
I've tried a lot of PLA from different manufacturers, 3DPrintz seems to be a good make
and I've just treated myself to an Elegoo Mars 4 Ultra resin printer (it has 18 micron pixels - the best I have seen in sensibly priced printers)
I also ordered a Mercury X post-processing bundle (wash and UV cure)
the Ender 3 is great for normal sized stuff, but not accurate enough for tiny details
I'm building a working winch
HTH
always happy to talk 3D printing
MikeMcP
Which 3D resin printer to buy...?
« Reply #74 on: June 21, 2024, 09:47:41 am »
I've now put my toe in the water and got myself a resin printer
Elegoo Mars4 Ultra with Mercury wash and cure station
it comes with a free license for "VoxelDance Tango" (I kid you not!)
but
received wisdom is that it is rubbish and is a mare to install on MacOS
I can confirm that installing is too big a mountain for me (with 999 years in IT!)
so the question for the crew is
which slicer to use?
candidates seem to be ChituBox and Lychee
I'm leaning towards ChituBox
opinions please :)
TIA
(mods if this should be a new thread . . .)
Pages: 1 2 [3] 4   Go Up
Page created in 0.019 seconds with 20 queries.
