Thank you for putting my fears for the safety of your Waverider to rest - and I shall incorporate some of your ideas into my build when I get to it (still haven't got my bench back yet!). Bringing these classics back to life, or recreating them, is a very worthy path to follow. I also have a partially built Lesro (Slec) Arrow and unstarted kits for a Sea Comander (modern re-issue) and a genuine Aerokits 46" Crash Tender kit (plus one I bought ready made). Basically still trying to fulfil my dreams from 50 years ago or more!
It sounds like you and I both have similar ambitions to try and fulfil our dreams from years ago - in my case more like 55 - 60 years ago!
Harry seems to have his Wave Rider performing well at high speed in Tasmania, so I think our Wave Masters should be able to go just as well when they are "the right way up" over here in the UK
Thanks to your wise words of caution, some small mods been added to help stabilise the model. If it needs more help, I will remove the small 'scale-like" chine spray rails and replace them with wider ones made from 1/4" x 1/8" obechie strips - or even laminate two layers of these strips if extreme measures are needed (classic 1960's fix).
One classic model that I have not acquired yet is the Aerokits Crash Tender and I think that every classic model boat collection should have one!
I think I would like to have a go at the 46" version, so if I should ever see one at the right sort of pensioners price I would be very tempted to find it a place in my waiting room, but suspect that it may do a bit of queue jumping as I have never had one of these and would enjoy running one - although the scale fittings would add a fair bit to the cost
Meanwhile - all 4 of the strakes and have been added so I just need to fix a water scoop and then I can finish-off the underside of the boat and start working on it when it is the right way up again!
