Author Topic: Best tools for measuring engine mount level  (Read 1608 times)
Troked17
« on: February 04, 2022, 11:48:49 am »
I am looking to level an engine mount for a better weight distribution and wondering what the best tool for the job is? I am currently using height gauge and making the sure the engine is level. however, the weight is not even and leans more to the left.
Whats the best method to overcome this?
Re: Best tools for measuring engine mount level
« Reply #1 on: February 04, 2022, 08:48:08 pm »
Despite the physical design, or appearance or type of model engines, they are usually pretty well equally weighted along the axis
If you say ...''needing placement to the left [Port side], suggests the right [stdb side] of the engine is heavier in mass along the axis of the engine
It also suggests it is an engine [reciprocating to rotary motion, and not a motor [purely rotary motion]
If the engine were inverted and suspended, what is the resulting off-angle of the mass to the vertical?
What type of engine are you contemplating mounting?
Mounting is critical, however alignment is also an element in the setup and mounting and require an understanding of where the next step in a build
A machine type height, or vernier height gauge is an excellent method of accurately determining height, however not necessarily understanding moments of inertia, which apply to your question of rotary balance
Why not post some images of the engine & vessel in question
