Pages: 1 2 3 4 [5] 6   Go Down
Author Topic: Aerokits Sea Commander.  (Read 36530 times)
zooma
  • Never too old to learn !
Re: Aerokits Sea Commander.
« Reply #100 on: July 29, 2023, 12:56:53 pm »
I have cut and fitted all of the deckings and the classic sloping front cabin cover, but I fancied being able to remove a section of this front cabin (it is normally fixed), so I took the razor saw to it and chopped a section out of it and made some 'shelf edges" for the cut-out section to sit on - without it the removed roof section would just fall through!  <:(
My obsession with being able to gain access to all the inside areas of the hull saw me reaching for the razor saw (as I do!!) and chopping out a nice shaped hatch with a front shape that will align with the funny little “wave breaker” that is a very recognisable part of this classic Aerokits design.
Unfortunately after I had cut the section out - it wouldn’t move !!
I had forgotten about my “belts and braces” fitting of the shaped former that sits underneath this roof section -another slight cock-up as I had "boxed myself out”.
My solution was to make yet another cut in the cab roof in line with the centre line to make one half of this roof section left out freely - and it did!
This gave me access to get the razor saw into the open area and to cut the top off of the roof former so I could lift this new hatch out from the hull.
I have now glued the two halves of the roof back together again and fitted some small shelving edges to stop it dropping through into the hull!
I think it will look quite good when it is finished ……..but wonder why I always feel the need to make a nice simple job a lot more involved than it needs to be.
« Reply #101 on: July 29, 2023, 05:32:42 pm »
Yup been there done that..........doh  O0
Probably never again though  :}
tonyH
« Reply #102 on: July 30, 2023, 05:51:08 pm »
Bob Zooma plays with his saw.......yet again!
zooma
« Reply #103 on: July 30, 2023, 06:20:18 pm »
Thanks for posting the pictures Tony, they show my new front hatch along with the mix of old and new wood that is being brought together  - hopefully to produce a complete Stilleto (are you reading this Will?) .....Sea Commander sometime in the not too distant future..... %)
zooma
« Reply #104 on: September 16, 2023, 09:05:43 am »
I have not had too much time at home recently, but I have managed to spend some of it  in the workshop (shed) to make and fit the front cabin roof.
The rear cabin roof should have been a lot easier to make than the front roof, but the new 4mm plywood baseplate that I glued the formers onto warped!
I removed the formers and clamped the baseplate onto the solid steel table of my bandsaw and after cleaning the glued surfaces I rebuilt it again.
The next morning I removed the clamps only to discover that it had warped again - but not so much this time.
This was now getting “personal” >>:-( . The obvious thing to do would be to cut some new wood, but I repeated the process of taking the front and rear roof formers off of the baseplate and cleaned the old glue off (again).
The baseplate was clamped down onto the bandsaw table and again checked to make sure that it was perfectly flat before gluing the two end formers on again, but this time I added a central spline with two half formers spaced equally on each side and added the the small side formers.
When the new assembly was still clamped to the steel table I added some diagonal cross strips between all the formers and left it to dry for the next day.
Fortunately this time the roof baseplate remained absolutely flat and so I was able to fit the plywood skin to cover it.......and leave it on the bandsaw table to dry overnight.
When I am home next, I just need to trim the skin to fit and both cabin tops will be finished making the construction look more like a  Sea Commander  :-))
tonyH
« Reply #105 on: September 17, 2023, 07:11:52 pm »
From Bob
zooma
« Reply #106 on: September 21, 2023, 11:37:31 am »
Both cabin tops are now finished and fitted, and the cockpit windscreens have been made and fitted with a short mast, so the basic construction is now completed and the model has been given its second coat of primer/undercoat and will gain its first coat of spirit based gloss paint very soon.
I still need to add some glass fibre matting in and around the engine bay and motor mounts - just to reinforce (although it looks strong enough already to be honest) and then I can start to paint the interior before re-fitting everything back into the boat.
The prop shaft, motor, coupling, steering servo, ESC and receiver can then be re-fitted.  These were fitted before the side skins were glued on so that the motor and shaft/coupling could be aligned more easily and platforms were made and fitted at this stage for the ESC and receiver to sit on when they were easy to see and fit.
Battery holding compartments were also fitted at this stage so the two LiPo cells can be slotted into position to give quick and easy removal for charging or exchanging for fully charged cells lakeside if required.
The steering servo mounts were also fitted before the side skins were glued-on and the linkages were made and tested at this stage.
Holes to take the water-cooling tubing and the servo wires were drilled and the installation checked and some small magnets were fixed in the rear compartment to hold some basic tools (Allen keys and a simple stamped steel spanner) "on-board" to allow basic lakeside adjustments to linkages, motor and coupling removal (or adjustment) and propeller replacement.
I will add a screwed stud (I forgot to do this) to hold a spare propeller so I should be able to take care of any minor incidents lakeside without having to carry a toolbox.
tonyH
« Reply #107 on: September 21, 2023, 01:13:15 pm »
More from Bob.
ChrisF
  • What's my favourite cake!
« Reply #108 on: September 21, 2023, 03:23:56 pm »
The paint is really tying the old and new together now. Should look really smart.
Chris
zooma
« Reply #109 on: September 21, 2023, 09:36:47 pm »
Thanks Chris - and Tony for posting the pictures for me  :-))
Once I have made a template for the unique Sea Commander "wave breaker" to fit on the front cabin I will get it cut and fitted to complete my "look-a-like" Sea Commander.
Then comes the job I hate the most - painting........and I have yet to come up with a suitable paint scheme!
I like to finish my new builds and/or restore my classic model power boats with a traditional oil based paint applied by brush - very time consuming - and I have yet to master the technique.........and finding good oil based paints is getting harder all the time - so I am NOT looking forward to the next few days/weeks with a paintbrush  <:(
I will make some basic cockpit detailing etc later, but first I want to get the main boat build finished and painted so I can run it and see how I get on with a non-water cooled ESC (a first for me)!
tonyH
« Reply #110 on: January 06, 2024, 10:26:11 am »
I'd suggested to Bob that he'd gone over to the "Dark Side" of ARTR so his conscience pricked him into sending these!
zooma
« Reply #111 on: January 06, 2024, 11:15:11 am »
Getting a good choice of traditional oil based paint colours is getting harder all the time as the manufacturers change their production to the more environmentally friendly water base "easy clean" types, so I mixed some of the blue and white paints that I had to give me a pale blue shade to try on the deck.  I think it looks OK so I will stay with it.
Stirring the non-drip paint removes its jelly like composition and it becomes much more like a normal paint and so it was easy to mix the two colours together and it has worked quite well.
The wave-breaker shape has also worked quite well (maybe a little bigger than the kit shape?) but once I have finished sanding it and get some paint on it I will decide if needs re-shaping or not, but for now I am happy with it.
I am using the wave breaker to protect the extra hatch that I fitted into the front cabin roof.  This extra hatch was worth making as it gives access to an area of the Sea Commander that is not possible to get into on the original kit built design.
The cold weather has further delayed the progress on this "copy commander" even further, but I am not in a rush (!) and I am pleased that the two delaminated and incomplete cabin sides that Will gave me by mistake have formed the base that encouraged me to restore them and cut the extra shapes that were needed to make them into the model that can be seen here.
zooma
« Reply #112 on: June 10, 2024, 07:41:57 pm »
A visit to the Bury Model Boat Club yesterday afternoon,
 (I arrived too late to see their open day events) has inspired me to look at my Copy Commander again with a view to getting it in the water in the near future.
All of the insides have been given a coat of gloss magnolia paint and the motor has been fitted and thread locked into the alloy water cooled mount and finally installed into the hull.
I started to touch-up the paintwork that has suffered from being left in my active workshop for too long and when dry I will double check the fine alignment of the Powerflex coupling before locking the motor mounts side adjustment screws and the Powerflex coupling to the 5mm shaft.
The motor has been connected-up with its integrated water cooling system but I am going to use the 120amp Surpass fan cooled ESC (not water cooled) to see how I get on with it before deciding to stay with it or replace it with my usual choice of water-cooled ESC.
I have never used a non-water-cooled ESC in any of my classic model powerboats, and I am hoping for the best, but the plumbing is already in place to allow me to fit a SeaKing 120amp ESC if I have any problems with the Surpass ESC.
The boat will be "water tested" before any final painting is completed, but it will be wearing the red, white and blue colours right from the start - its just that hand painting with gloss paints really needs lots of coats of paint and rubbing down in-between them to achieve a fine finish, and I don't want to wait any longer  - so although it won't pass any fine finish inspections, it will get to see some action on the water very soon.
The boat will carry a pair of 2C 7600mAh LiPo battery packs - fitted low down, one on each side of the hull under the cockpit floor  (the cockpit will not be detailed in time for the water trial either) to give good "working ballast" that will hopefully be found to be in the right place!
Any decorative accessories that may be fitted will also follow after the performance trials - just in case any serous (unexpected) modifications need to be made.
Hopefully I will be able to close the chapter on this lengthy new build with a successful performance either on the local Bury Club waters or on its home lake at Southport.
zooma
« Reply #113 on: July 11, 2024, 03:47:38 pm »
My Kopy Kommander finally completed her 'sea trials" on the Southport Club lake last week and generally performed very well.
The model lifted up quickly onto the plane, was well balanced and had plenty of speed using a 45mm prop I will do some further testing with a 50mm prop and a 45X prop.
The non-standard stakes looked good and may or may not have contributed to the good performance?
The model made a some strange (vibration like) noises at 3/4 throttle that quickly disappeared as the revs increased.  I checked that the coupling and motor etc was tight and that the prop shaft still had a small amount of free play in it so at the moment it is a mystery.
The boat has a new well greased M5 prop shaft and has a perfectly aligned new Powerflex coupling so I am testing the different prop sizes to see if this helps to remove the mystery "vibration" type of mid-range sound.
madwelshman
  • Learning all the time.
  • Fairey Marine Fanatic
« Reply #114 on: September 04, 2024, 12:48:44 pm »
Fantastic news Bob, she looks very smart and I'm really pleased that you've got her bottom wet and that she performs as well as you hoped.
We look forward to seeing some action shots, and a video would be even better again.
Will
49" Precedent Perkasa
46" Aerokits Sea Queen
42" Veron Fairey Huntsman 28 x2
34" Lesro Sportsman mk1
34" Precedent Fairey Huntsman 31 x3
34" Aerokits Sea Commander x2
29" Aerokits Sea Rover
20" Aerokits Fast Patrol Boat
16" Aerokits Sea Urchin
canabus
« Reply #115 on: September 05, 2024, 10:45:36 am »
Hi Zooma
The [/size]strange vibration may be in the hull bottom skins !!
[/size]WE have had that in some boats like the Spearfish so we add two 6mm square timber 3/4 the length of the boat inside.
[/size]
[/size]Canabus
zooma
« Reply #116 on: November 25, 2024, 10:20:44 am »
Hi Zooma
The strange vibration may be in the hull bottom skins !!
Canabus
Thats an interesting thought.
I will take a look at that.
zooma
« Reply #117 on: May 28, 2025, 11:17:28 am »
I did notice that the Copy Commander did not run as naturally "dry" as my Rapier with some spray water getting in through the window openings (my Rapier still runs today "dry" inside  - and I have never glazed any of the window openings!
The windows need glazing to keep the inside of the hull totally dry during normal operating conditions, so I want to find out what sort of adhesive to use to glue the clear plastic glazing into the inside of the cabin sides.
Another option, would be to make some external "frames" to sandwich the clear plastic between them and the outside of the cabin sides. I have seen this idea used on later versions of the reproduced Sea Queen kits and it does not look too bad, but I have not seen this idea used on the smaller Sea Commander.
Of the two options mentioned above, I think I would prefer to keep the clean lines of the cabin sides and glaze it from the inside.
canabus
« Reply #118 on: May 28, 2025, 01:32:40 pm »
Hi Old Fruit
I use airplane canopy glue!!!
Restoring a Sea Rover at present after finishing a Billings Kadet(June Model Boats Mag).
Canabus aka Harry
zooma
« Reply #119 on: May 29, 2025, 07:57:40 am »
Hi Old Fruit
Canabus aka Harry
Good to hear from you Harry, and thanks for the tip.
I am guessing that the canopy glue will not cause the plastic glazing to "fog" so I will check out my universal suppliers (Amazon and eBay) and get myself some.
The Sea Rover is probably the only Aerokits model that I have never owned, but I do like the look of it and like the removable sun canopy idea, so maybe (after too long a lay-off) when I get my model boat mojo back again it is something for me to consider after I complete my Swordsman.
Meanwhile, I am hoping that you will start a Sea Rover blog on here so I can see how your restoration progresses.
Stay safe - Bob.
zooma
« Reply #120 on: May 30, 2025, 10:11:52 pm »
I have an iPhone 16 (basic model) and if I can work out how to send pictures from it to this site, I will send some of the "Kopy Kommander" on the water as she is now.
tonyH
« Reply #121 on: May 31, 2025, 08:43:49 am »
Oh Yes? {-) ................................!!!!!! :-))
zooma
« Reply #122 on: May 31, 2025, 09:42:37 am »
Hi Tony,
Hope all is well with you,  and thank you for posting all of my previous pictures for me due to my inability to post them myself on Model Boat Mayhem.
Posting pictures on any of the other forums that I get involved with is quite a simple process that even a simpleton such as myself can manage, but posting pictures on this forum is not quite so easy a process from an iMac or an iPhone...........but I would like to see if the process has improved....... or if I can grasp the transfer method myself  this time .
The odds may not be too good (given the previous history) but I will take another look.................
Stay safe and thanks again for all you help  :-))
Bob.
tonyH
« Reply #123 on: May 31, 2025, 10:43:53 am »
Good morning Bob!
It was always a pleasure and please don't worry about me moving back to the "Dark Side".........the photo transfer system is still available if you wish!
zooma
« Reply #124 on: May 31, 2025, 11:15:08 am »
Not sure how I did this yet - but I have uploaded a picture of a Tiger 1 that I was airbrushing !
I will try again with a picture of my Kopy Kommander, but for now the image of my advanced spray booth has made it onto the site - once I find out exactly how I did it, more relevant pictures may follow..................
Pages: 1 2 3 4 [5] 6   Go Up
Page created in 0.175 seconds with 21 queries.
