Hi, I had a look, but no option for shipping to uk. I really have to stick to what I have just now, my budget is pretty maxed out with my Javelin builds, I am hoping my 25mm props, 7.4v, sympathetic use of throttle and careful monitoring for heat will keep it all working.
I have a 1700kv motor, but it is an outrunner, I had planned to get round its cooling issue, not getting any air, by putting it in the boat with a cooling fan and building an outdrive using selected parts of the outboard, ie the bits with bearings and shafts. I have already printed the parts I need, just waiting on some bearings and gears.... And a final plan of how I am going to do it, the main bits are perfect, just have to be held together and attached to the boat. It would work perfectly with a big blob of hot glue encasing everything.... But I want it looking fairly good. The outdrive has to have the rudder on it too.
I will post some pictures once I start fitting bits together.
Hoping to get a black printed outboard fitted out with mechanics today... or tomorrow😁
No rush.
Cheers for finding the motor, much appreciated, I will get one as soon as I can, these outboards deserve the proper stuff, to me, it is the only way to go, commercial stuff is way too expensive and doesnt usually look like a real outboard, or have any tinkerability.
These are a little side project for me, the filament costs are low, the bearings and gears can be swapped around if you wanted to print different coloured ones, just more possibilities.
Often in the past, browsing through my plans catalogue, I would find something I really liked, but it was for outboard. Now, a whole new branch of boat designs is available.
I am even putting one on a Javelin, which is an inboard design.
Hopefully the new black prints will be plenty strong, they certainly feel much stronger, time will tell......
