Hi Ronnie42,Some guidance for you ...... it is clear from the photo that your antennas are very poorly positioned. As has been pointed out, it is only the the last circa 35mm that is the actual antennas, most of the length is a screened cable. Reposition the receiver so that one antenna is vertical and the other either horizontal or at 45 degrees. The way you have the antennas positioned currently they are close to being below the waterline. This is why it works when close to the TX but fails at a distance. Also locate the receiver away from other electronics (i.e. motor, ESC, etc) and clear of other wiring.Hope this helpsSteve Dean.
