Thank you for such comprehensive and helpful replies. Re the endurance event, at first glance it seems easy, but as you have realised, the more you think about it, the more there is to it. I am loving Dereks tactics of racing into the lead, then slowing down to keep pace with the following pack. The winner of the event is the boat that has completed the most laps and is still moving, so its about going as fast as you can without running out of power (steam, batteries, etc).
Thank you for the link to a previous Mayhem thread, you are right there is a lot of relevant information there.
Testing on the bench shows that a large portion of the steam oil is lost from the displacement lubricator at the start of running, so once the engine is hot, its worth shutting the steam off, topping up the displacement oiler and then running.
The same thing happens with the oil seperator, so again once the engine is running and hot, empty it, then it seems fine.
The engine has been running at 4 bar but is rated at 6bar, the boiler has a steam drying loop that drops into the fire box and back out to the engine. The gas jet fitted is a No 8 and having weighed a gas tank before and after a bench test run, 100g/hr is what it is using. I agree the controls will help with minimising the gas consumption.
Re Oiling the moving parts I will look into fitting a tank with small pipes that drip oil on the relevant moving parts - old school style, since its not easy to reach the engine with a syringe to oil it. Any advice or experiences with this method would be most welcome.
The prop fitted is the largest I could fit without modifying the hull, its from PropShop, its 80mm by 1.5 pitch 4 Bladed Prop, it is a thing of beauty. The hulls waterline is 125 cm long, its breadth is 25cm and its depth is 13cm
Re the water supply, what I have learned from the bench testing and previous experience with my first tug, is that the water is used in the boiler until the water level drops to sight gauge sensor level, it then never gets lower. So if this is set at 2/3 and the boiler capacity is 0.6 litres, then only 0.2 litres maximum of water is used from the boiler, as soon as that has been used, the rest of the time the water used by the boiler is coming from the external supply (tank or lake). So to get the best run times when using on board water tanks, the sensor needs to be a bit lower in the boiler. The Boiler controls then take over to fill the boiler until the water level goes above the sensor, then for a further 15 seconds, the controls keep cycling in this way to maintain a more or less constant level of water in the boiler.
