The Shipyard ( Dry Dock ): Builds & Questions > Yachts and Sail
Can anyone identify this kit/model
Riot van:
Picked up this RC sail boat second hand. Seller didn't know anything about it. I really liked the look of it and bought it.
Its a fiber glass Hull with wood mast, decks and superstructure etc.
The Hull looks exactly like a Revell Inga IV but the superstructure is totally different as well as the rig. It also looks like it either had 2 masts at one point or possibly the kit had the option to fit two masts. Perhaps its a custom design using an Inga Hull or modified Inga.
Can anyone identify it?
mrzippy:
Yes it looks very much like a 'Hegi' Inga IV hull with custom superstructure,
original kits had 2 masts and auxiliary prop propulsion, check out the overall length 1100mm etc to be sure.
Kingston Mouldings from Bournemouth area also produced Inga IV glass fibre hulls
therefore it's likely to be one of these with a freelance superstructure.
Paul.
nemesis:
Inga, We run a fleet of 10 plus, excellent vessel and a joy to sail. nemesis
Riot van:
--- Quote from: nemesis on April 16, 2022, 06:21:08 pm ---Inga, We run a fleet of 10 plus, excellent vessel and a joy to sail. nemesis
--- End quote ---
OK thanks. Would it still be considered an Inga? The rig is different to the standard kit so I guess someone built this from a Kingston mouldings Hull. Is it the Hull that defines the class?
I guess since it was possible to purchase a Hull then there are probably many different designs featuring this same Hull?
roycv:
Hi Inga IV is a full size yacht.
https://www.facebook.com/Inga-IV-Classic-Yacht-for-sale-256791811498028/
Not sure if the full size yacht is still for sale.
I have seen photos showing mast detail and the kit model is either a simplified model or the prototype has been updated.
So not a class but a single full size yacht which has been re-created as a model. I have one myself and she sails very well. I recently was lucky enough to come across a new set of sails and this is what she has now.
There is room for much detail on the deck and the original sail set up is better than the one you have illustrated which is a not very good attempt at a gaff rig, which this hull would not really have ever had.
Plans for the kit are relatively easy to find and it is worth seeking them as if you like a bit of woodwork and marquetry then you will enjoy it.
The engine is optional mine has an electric motor. You do not need much power to propel a yacht and you will never overcome the effect of the wind on the sails so regard it as a way of recovery when the wind drops.
The group up north are experienced sailors of this hull and my old set of red sails went to them a few years ago.
Personally I would ditch the current mast sail set up as it does not do the hull any favours.
Best of luck
Roy
Navigation
[0] Message Index
[#] Next page
Go to full version
