Author Topic: Turnigy 6 XS RX.  (Read 850 times)
old man
Turnigy 6 XS RX.
« on: May 06, 2022, 06:25:54 pm »
Hi, here we go again. More electickery abounds.
Short story, saw a tug "Yorkshireman" bought it complete with above RX.
Asked for the controls to be switched to my preference from previous. I wanted the light and horn function moved from right stick to left.
The previous owner gladly tried to do this and gave up after a long frustrating episode. The left stick un-sprung vertically will not function the lights/horn function. Another RX failed too?
Question from an electro numpty.... does anyone know why this could be and what would be a solution please?
My choice is Right stick vertical... forward/reverse.     horizontal... bow thruster left/right.
Left stick Vertical... lights etc.     horizontal...rudder left/right.
My idea was to use the un-sprung vertical for control of items that didn't need positive end point control for docking etc?
Thanks again.
om
Not sinking just yet but control is problematic.
No smoke or grinding is a bonus!
JimG
Re: Turnigy 6 XS RX.
« Reply #1 on: May 06, 2022, 08:23:21 pm »
Exactly how are the lights and horn activated, is it an electronic switch or servo and microswitches? Some transmitters have the movement of the unsprung stick mechanically restricted, this is the throttle stick for aircraft so can use less movement. If it is using a digital switch then it may not be seeing enough change at the endpoint to trigger the switch, try increasing the endpoint adjustment in the menu , e.g. over 100%, and see if the switch works then.
Jim
Dundee Model Boat club
old man
« Reply #2 on: May 07, 2022, 10:02:38 am »
Thanks Jim, not sure till collect boat Monday. Just aware that on that channel 3 positions for lights and also horn? Up for activation down to cancel. Up 1/down 1. up 2/down 2. etc. slight delay on cancellation.
om
old man
« Reply #3 on: May 07, 2022, 02:13:37 pm »
Further considering the end point situation I have remembered that prior to requesting the stick change I couldn't get the lights/horn to cancel on the right stick?
Much to learn?
om
old man
« Reply #4 on: May 11, 2022, 06:21:31 pm »
Unable to water test the tug as too windy but worked fine dry.
Waiting for spring kit to come from China, now wondering can anyone please tell how to move end points on this set as need the info please.
Thanks again
om
Page created in 0.099 seconds with 22 queries.
