Author Topic: Easy to print & build - trawler, tanker, and aircraft carrier  (Read 2136 times)
CPomeroy
  • Ahoy there
« on: August 07, 2022, 04:10:19 am »
In my eternal pursuit of The Minimum Viable Product(tm), I've thrown together a set of designs for a bit of a laugh. These egg-boats print neatly and use only the bare minimum of parts from the spares box, so won't run up a horrendous parts bill.
Two metal gear micro servos, two 18650s, a receiver, some tube and wire, and you're off to the races. I printed my tests in about 20 hours each and had them sailing two hours later so it's a fun wee toy for a weekend. It's not exactly high-end scale modelling, but it's occasionally nice to make things just for fun as well!
Hope they're of use to someone!
https://www.youtube.com/watch?v=uPW79hIy6N8
https://www.thingiverse.com/thing:5451561
Re: Easy to print & build - trawler & tanker
« Reply #1 on: August 07, 2022, 07:27:49 am »
Which prop is more efficient....the 2 blade, or the 3 blade?...... Derek.................  :o
CPomeroy
  • Ahoy there
Re: Easy to print & build - trawler, tanker, and aircraft carrier
« Reply #2 on: August 07, 2022, 01:50:49 pm »
That I can't say for sure! I picked the three blade for my tests and it didn't seem to cause the motor to struggle at all. They're of course not going to be properly formed propellers, so efficiency gains are probably marginal and the boat has two enormous 18650s anyway, so the battery should last quite a while.
I've also just drawn and uploaded another superstructure form, this time of an aircraft carrier (the USS Leggsington... badum tss).
ScottW
« Reply #3 on: August 07, 2022, 01:56:08 pm »
Nice photo with the sunlight. :-))
There is much truth in that,
"If it is something that you can make use of, that's a bonus, but the real value is in the creation." Steve Bennett; Sidelines
Umi_Ryuzuki
    • Models and Miniatures
« Reply #4 on: August 08, 2022, 02:01:10 am »
Very Nice.  :-))
