Author Topic: Cost of living vs Boating Hobby  (Read 6282 times)
Re: Cost of living vs Boating Hobby
« Reply #25 on: August 25, 2022, 11:19:54 am »
Have a look at Vic Smeeds 'Krispie' Scott, Kellogs finest.
roycv
« Reply #26 on: August 25, 2022, 11:38:51 am »
Vic Smeed was thinking cardboard when he designed the sailing yacht Krispie.  You need quite a few cornflake packets for that one.
I ended up after an auction of deceased members models with a small warship, looked quite good. ran it a few times it is quite small and runs on twin servo motors.
A friend helping had another similar one.  He said he left his in the water and it started to come apart!  Seems the builder used sticky brown paper onto a balsa frame.
However it might have been better to have waterproofed the frame before putting on the sticky stuff.  Left mine on the shelf after that.  Also found that with one esc, one of the motors usually the same one would not start without a flick, then OK.
Roy
Tug Fanatic
« Reply #27 on: August 25, 2022, 04:16:45 pm »
...................... Seems the builder used sticky brown paper onto a balsa frame.  ..................
Roy
Sticky brown paper parcel tape was a common building material. Generally it was well coated with Shellac when completed. It made good strong and light hulls. I am sure they were not intended to be left in the water for extended periods but then I am not so sure that a modern model is either.
Page created in 0.045 seconds with 21 queries.
