Author Topic: Sonar on PCS WW2 VESSELS  (Read 2670 times)
tassie48
  • bikes birds and burnups
« on: September 08, 2022, 04:39:16 am »
Hi crew I noticed on the Patrol Craft Sweeper WW 2 there is a sub sonar device under the hull my question was it a drop down Thur the hull or was it a swing down type aft facing swing downs and retracts back up into place interested in how it worked tassie48
tonyH
Re: Sonar on PCS WW2 VESSELS
« Reply #1 on: September 08, 2022, 09:02:28 am »
You  might get something from this http://archive.hnsa.org/doc/sonar/index.htm for the fixed keel or drop down type but the system kept on changing anyway. Otherwise it's a trawl through  http://www.navsource.org/archives/11/19idx.htm for the photos of the original YMS/BYMS kit such as the pic below for BMS2041 (Look up wildfire3)  :-))
Akira
« Reply #2 on: September 08, 2022, 08:47:34 pm »
While these plans are for a PCE, they are very close to a PCS. They show a drop down sonar. I hope this helps.
https://www.hnsa.org/wp-content/uploads/2014/08/pce874.pdf
tassie48
« Reply #3 on: September 10, 2022, 01:14:18 am »
Thanks crew appreciate the input going with a drop down type lower down lift up many thanks for the help tassie48
tonyH
« Reply #4 on: September 10, 2022, 02:17:58 pm »
Hi Gregg,
What derivative are you actually going to build?
Tony :-))
tassie48
« Reply #5 on: September 10, 2022, 10:23:33 pm »
Tony hi still looking do like the PCS 1386 extra guns and Depth Charge throwers normally I pick a vessel with a good history this time just going for a normal everyday boat like 1386,  i am waiting on both sets of plans to arrive , I enjoy doing the research side of things looking up the ships history crew etc , going 12 channel operation 1/24 scale good size model 1728x312x110 mm , I have started the build book listing all the different items have 88 pages so far from flags to paint codes do like this research side of things .tassie48
tonyH
« Reply #6 on: September 12, 2022, 06:19:29 pm »
Hi Gregg, the one on it's way has 2 extra d/c throwers but loses the main deck 20mms to create space.
Page created in 0.012 seconds with 20 queries.
