Hi All
I'm looking for a lazy method of charging a collection of NiMh batteries. I've got a varied collection of NiMH packs ranging from 6v to 9.6v & various capacities. They are installed in various boats, some as single packs & some in series. I'm expecting to add parallel to the mix soonish.
My current solution is to put each boat on the work surface one at a time, disconnect the batteries, connect a cheap NiMh charger (with a temperature sensor) to each pack one at a time and then manually keep checking on it until I've worked through the whole fleet.
I'm hoping to find a single charger that has multiple connection ports where I can essentially connect a cable to each pack in-situ with the boats and just leave the charger to it.
I've become a bit lost in all the options available, most of which seem to be aimed at LiPo. I know I could just buy enough chargers to dedicate one to each battery pack but this seems a bit costly.
Does anyone know of any such solution?
