Author Topic: Robbe/Futaba Decoder  (Read 2326 times)
destroyer42
« on: November 04, 2022, 11:59:27 am »
Hi All,
Looking for a Robbe/Futaba 16 decoder if anyone wants to sell one or know where I can get one?
Destroyer42
tsenecal
Re: Robbe/Futaba Decoder
« Reply #1 on: November 06, 2022, 01:33:06 am »
this company sells a replacement that works fine with the original robbe/futaba part.
https://wetronic.nl/
look under the electronics tab, then multiprop/multiswitch
destroyer42
« Reply #2 on: November 06, 2022, 09:20:31 am »
Hi Tsenecal,
Yes, I have been in communication with Wetronic in the Netherlands, but they are not sure if their modules would work on my F14 & F16 transmitters as they are both converted to 2.4GHz as well as 40mhz by using the Futaba T-M 24 conversion module. This module works with the original Robbe/Futaba muliprop/multiswitch modules, but they are not sure about the wetronic modules working with 2.4GHZ conversion and I don't want to invest in their modules for them not to work.
Destroyer42
tsenecal
« Reply #3 on: November 06, 2022, 03:15:21 pm »
destroyer42,
do you know the exact model number of the futaba 2.4ghz upgrade kit?  for both the f14 and f16, and can you check and make sure it is an f16 and not an fc-16?
finally, if it is an fc-16, is it using separate 40mhz and 2.4ghz modules?
ex docky
« Reply #4 on: November 06, 2022, 06:34:17 pm »
pm sent
Ex docky
destroyer42
« Reply #5 on: November 06, 2022, 06:51:47 pm »
Hi tsenecal,
The transmitters are the F14 navy 40mhz & 2.4 ghz ,the FC-16 40mhz & 2.4ghz boat &truck. all you do is if you are using 2.4ghz you just remove the 40mhz crystal and flick a switch over to 2.4ghz for both transmitters. Below is the conversion module details.
TM-24 FUTABA 2.4 GHz T-FHSS Module F-Series item P-FTM-TFM
If you send my you PM email address i will attached the details/instructions for the module or you can download them from Ripmax site, but I understand that you can't get them anymore.
Destroyer42
Page created in 0.403 seconds with 21 queries.
