I have given up trying to sell my (bought used) 46" Crash Tender and am refitting it with a brushless motor and hope to have it on the water in the spring.
I have removed the original brushed motor, a Torpedo 850 with a claimed 157 Watts (unsure whether that's its consumption or output) and am replacing it with a 1350 Watt brushless.
Having removed the prop shaft from the tube and measured it, it is 3/16" diameter (not too surprising for an old British kit) but the thread at each end is 5mm - i have checked it against several 5mm bolts and a 5mm nut is a perfect fit. This obviously means more choice when choosing props, but I suspect that if the bearings in the tube aren't worn out already, they won't last very long with almost ten times the power passing through them, which is likely to mean removing and replacing the whole drive system, which I have done on other boats, but it's never easy, and the Crash Tender has a substantial ply keel to get it out of.
Are mixed metric/imperial shafts common, or has this been bodged together by a previous owner? If it looks like it's going to present me with a problem, I'd rather remove the shaft and replace it with a metric one now, as then at least I'll have peace of mind and wider range of props to try.
Any observations/comments/advice/insults will be gratefully received.
