Now it was time to continue (apologies if my terminology if off) along the gunwales. I framed out a few inches at the rear for a small planked deck there. I wasn't sure at this point if I was going to continue the rudder upwards and have a visible tiller arm or go with a more hidden linkage to a forward mounted ships wheel. Research shows that both are popular so for now I'm just going to leave my options open. I cut wider strips of 3mm thick walnut for the gunwale planks and staggered and slightly angled the ends of the planks so the joins will blend in. The width is to accommodate the curve of the hull and they will eventually be sanded flush inside & out to meet with vertical planks to give a good finished edge. I worked in sections about 6 inches long, clamping with toolmakers clamps as I went. At some points I also used weights where the curve of hull was more forgiving.
Progress was limited by the amount of clamps I could lay my hands on, I think I used regular wood adhesive here but I can't remember. The other advantage to cutting the planks off at an angle, was that I made sure that the last plank ended up with two opposing angles, so it was a trapezoidal shape. This meant that I didn't have to be exact with the cutting to length as you can just insert it from the side until the angled ends meant the length is correct. If the angles don't meet up exactly, just sand a bit and then as it's now shorter it just goes a bit further in but still fits exactly because of the angled ends.
I was getting quite into it by this point so decided to fit a curved front to raised 'coaming?' that I was going to fit across the inside. Not really sure on the terminology for this part. I cut three strips of walnut and laminated them together between two curved plywood formers. Took two attempts to get it right but I was happy with how it came out eventually. I notched the ends so it sat down below the deck level and figured it would nicely hide a removable panel to cover where it might install some of the radio gear.
You can also see in these last two images how I have installed a 6mm x 4mm walnut rubbing strip around the outside to tidy up and reinforce the edge of the gunwale planks. This was quite simple to clamp in place once the outside had been sanded flush. I had a bit of trial and error with the size but eventually settled on what I like the look of. The plan was to sand the top edge to match the curved profile of the foredeck. Actually worth mentioning that although the foredeck is curved, the effect is barely noticeable now it is planked and if I could do it again, I would exaggerate the curve to make it stand out more.
I cut long strips of walnut for the inside coaming, only about 3mm thick but about 18-20mm wide this should give a nice slender scale effect whilst standing up nice and tall. I've not mentioned previously, but by this point in the build I had settled on 1:12 as the scale for the build which puts the full size boat at about 28ft. I'm not overly worried about the risk of water coming over the side as I have sailed a similarly proportioned hull for many years and never had issue, however with this being a deckless boat, I wanted to make sure I had every mm of freeboard I could get while looking in scale, hence the tall coaming. This can always be trimmed down later if I want. Fixing the coaming in proved to the shockingly simple. I used offcuts of the walnut strip, wedged in place to hold the coaming in while it glues. I was expecting this bit to be really awkward so this was a pleasant surprise.
