Author Topic: Club 500  (Read 2663 times)
terry1956
Club 500
« on: January 25, 2023, 03:59:28 pm »
Hi chaps.  Is there anywhere that gives good instructions and information on building the club 500 speed boat. Is there a better way of joining the two hull sections together then edge to edge. Thanks
Re: Club 500
« Reply #1 on: January 25, 2023, 04:51:06 pm »
A quick google provides lots of responses for instructions. On my model the superstructure fitted over the hull not edge to edge. The tip I was given was to use batroom sealant to join the two. This gives a firm connection but allows a little flexibility for the inevitable collision when racing.
terry1956
Re: Club 500
« Reply #2 on: January 25, 2023, 05:18:12 pm »
Thanks. I have only found part builds but nothing that goes into much detail.
TheLongBuild
  • Build em, and play hard..
Re: Club 500
« Reply #3 on: January 25, 2023, 06:09:08 pm »
As mentioned above the top should go over the bottom section by about 10mm
terry1956
Re: Club 500
« Reply #4 on: January 25, 2023, 08:38:16 pm »
Barney Magrew
Re: Club 500
« Reply #5 on: January 26, 2023, 10:13:17 am »
I glued mine in a few places, just to hold it as I worked on it, and when dry, filled the gap with clear sealant all the way around.
TheLongBuild
Re: Club 500
« Reply #6 on: January 26, 2023, 04:53:40 pm »
Also to cut it out I found that using a Dart to score it out worked better than a blade..
terry1956
Re: Club 500
« Reply #7 on: January 26, 2023, 04:55:36 pm »
Thanks chaps. Looks like I have a bit of work to do. Mine you with the weather the way it is, making this little boat should be fun. I hope.
Fastelectrics
Re: Club 500
« Reply #8 on: January 26, 2023, 10:16:11 pm »
When I was racing, it was considered that the best way to stick the deck to the Club 500 hull was to use the waterproof version of No More Nails.
terry1956
Re: Club 500
« Reply #9 on: January 29, 2023, 03:28:34 pm »
Thanks chaps. So far I have the motor etc in place and have trimmed the hull sections. The top section 15mm at the rear 3mm at the bow. However I am finding putting the two sections together is like trying to hold a greasy pig. No matter what I do one side will pop out, or the bow or the rear. I just can’t get the two sections to fit. Is this normal ? What have you done to get these sections to mate up. Also should I use an hard glue with a silicone sealer on top. Or just use no nails. Thanks
TheLongBuild
Re: Club 500
« Reply #10 on: January 29, 2023, 07:17:23 pm »
Tape.
Bustergrunt
Re: Club 500
« Reply #11 on: January 30, 2023, 12:45:30 am »
I’ve just finished building my 2nd club 500. I found that ensuring that the hull was trimmed off as described in the manual, allowed the top to fit onto it…if it was Insufficiently trimmed, the top part just wouldn’t go on.
I used a palm plane to trim down the hull, with masking tape that had a line drawn on it where to trim down to.
Do a little at a time until you can achieve a snug fit
Page created in 0.317 seconds with 21 queries.
