Pages: 1 [2] 3   Go Down
Author Topic: T45 - HMS Duncan Build  (Read 23844 times)
madrob
Re: T45 - HMS Duncan Build
« Reply #25 on: April 02, 2023, 06:02:24 pm »
enjoying this build  :-))
looking good
Tworrs
« Reply #26 on: April 02, 2023, 08:42:31 pm »
Great progress, she is looking really good.
jonggd
  • The Fleet!
« Reply #27 on: April 05, 2023, 06:47:13 pm »
Cheers guys  :-))
In the Dockyard...
1/128 HMS Warspite - QE Class Battleship
1/72 HMS Campbeltown - T22 Class Frigate
1/72 HMS Apollo - T12I Leander Class Frigate
1/72 HMS York - T42 Batch 3 Destroyer
On the Slipway...
1/72 HMS Duncan - T45 Destroyer
jonggd
  • The Fleet!
« Reply #28 on: April 07, 2023, 11:20:14 am »
After completing the ballasting with the batteries installed I created the nests to locate them, then installed the tillets and stabilizers. I can now fix down the helideck and start work on the hanger, which will be removable to allow access to the motors.
In the Dockyard...
On the Slipway...
frogman3
« Reply #29 on: April 07, 2023, 11:27:27 am »
HI WHATS in the orange box ? an i just wondered why you have such long push rods on your rudders mounting an this is not critisum of your build but just an observation
chrisb
jonggd
  • The Fleet!
« Reply #30 on: April 07, 2023, 06:33:50 pm »
Hello Chris,
I assume you are referring to the orange box in the first picture, that's one of the 12v batteries. I inherited the model and the rudder servo was already installed, did consider moving closer to the tillers, but then it would be hard to reach if it needed to be changed. In its current position, it can be reached via the removable hanger floor. Tested it and works OK, with no noticeable flexing. Regards Jon
In the Dockyard...
On the Slipway...
jonggd
  • The Fleet!
« Reply #31 on: April 15, 2023, 09:03:57 am »
Made progress on the hanger internals, which is made in four sections so that they can be removed once the hanger roof is lifted off. I did a trial assembly and found it a challenge but possible to install and remove. This will give access to the motors if ever needed, hopefully, I will never need to take it all out once finished. Just a little more detailing and some paint and the hanger can be completed. I hope to start painting the hull, weather permitting this weekend.
In the Dockyard...
On the Slipway...
frogman3
« Reply #32 on: April 15, 2023, 10:21:16 am »
HI very nice work in the hanger bay with the walkways an railins an yes good idea about makin it removeable to get to the motors an such as some time the motors may burn out as access to this area is a must as i also am back to motor probs on my tiger so im busy today tryin to find out whats causin the prob as the rear motors go great but the other have always been a prob so i have replaced them with grupner 600 motors an they work great so if still a prob then it must be the esc but your model is comin on great keep pics comin
chrisb :-))
Rob47
« Reply #33 on: April 15, 2023, 01:39:11 pm »
Chris
Have you still got them running from the one esc?
I will finish this model
frogman3
« Reply #34 on: April 15, 2023, 01:59:45 pm »
Chris
HI Bob ive never had the motors running from one ESC as ive two ESC 's in the ship but ive now found out the problem an now all 4 motors all go perfect thank god but the problem was a bad lose connection on the cutoff switch but this i fitted in under the flight deck so could not see it only way i found it was with a circut tester but they all work now fine but that lose connectin was buggin me for months AN HOPE YOU ARE WELL BOB
chrisb
ATB
Rob47
« Reply #35 on: April 16, 2023, 05:40:41 pm »
loose connections can be a nightmare, so know what it must have been like, had one on Bristols and it took ages to find
Yes still ok here hope Jen is ok as well.
jonggd
  • The Fleet!
« Reply #36 on: May 01, 2023, 08:59:53 am »
Finally had some decent weather this weekend and managed to get the hull painted.
In the Dockyard...
On the Slipway...
Tworrs
« Reply #37 on: May 01, 2023, 10:45:23 am »
She's looking really good Jon, well done.
Garry
« Reply #38 on: May 01, 2023, 12:13:39 pm »
Looking good there Jonggd!   :-))
« Reply #39 on: May 01, 2023, 12:40:26 pm »
Very smoooth :) Lovely work.
jonggd
  • The Fleet!
« Reply #40 on: May 06, 2023, 11:58:55 am »
Continued with painting the Hull, I've been working on the deck hazard markings. I have in the past used self-adhesive hazard strips but found they can lift off over time and so have decided to go back to my old method of painting them. I start with a base coat of yellow and then mask off each spacing and apply the black. Once dry I remove the mask and then reapply the mask where the hazard marking should be, then spray the main deck medium grey.
In the Dockyard...
On the Slipway...
jonggd
  • The Fleet!
« Reply #41 on: May 07, 2023, 09:25:55 pm »
Added the pennant number and depth marking today, just requires a coat of lacquer to seal and she is ready for her first sea trials.
In the Dockyard...
On the Slipway...
jonggd
  • The Fleet!
« Reply #42 on: May 12, 2023, 12:54:13 pm »
Made a start on adding some of the fine detail to the model. Been working with the etched sheets from Scalewarships, which are very good, if not a bit fiddly to work with, especially as the eyesight is not what it was, definitely a case of "Should have gone to Specsavers" %)
In the Dockyard...
On the Slipway...
T888
« Reply #43 on: May 12, 2023, 04:14:18 pm »
Jonggd,
Yes!  ScaleWarship do produce very good PE Frets and you have done a nice job fitting them.
Regards David
South Coast Modellers
frogman3
« Reply #44 on: May 13, 2023, 08:12:43 am »
HI Jon she's lookin good excellent paint finish an in 1/72 scale like my tiger how long is she ? an beam ? an yes them scalwarships p/e really sets the model off brilliant an glad to see she passed her test tank trials ok as im at that point at the moment on my tiger waiting
for warm sunshine so i can get tiger in the test tank to check how she sits an stability an for leakes an me an boat chums went over HMS DAUNTLESS  when she came to gr yarmouth an i must admit i dint like the T 45 with that massive mast an the design of the ship but i see her in real i have changened my mind an think they look less clunky an more gracefull than i imagined the real thing would be an a question please why have the R/N not fitted safetey railins  right up to the bow as yes i know the ancor chain capstans  an chains are all in side the bow but just seems strange to see them stop just past the gun
ATB
chrisb
jonggd
  • The Fleet!
« Reply #45 on: May 14, 2023, 03:07:01 pm »
Hello Chris,
The model is nearly 7Ft long and has a beam of 12inch. I was not a big fan of the T45 design, but it has started to grow on me. I believe the railings do not continue all the way to the bow as she has an enclosed forecastle, so there is no need for crewmen to work in this area.
I hope to get her in the water soon once we get a dry/warmer weekend. I have yet to check if she will fit in my car  :o .
Best Regards
jon
In the Dockyard...
On the Slipway...
frogman3
« Reply #46 on: May 14, 2023, 09:16:00 pm »
Hello Chris,
Best Regards
jon
HI Jon thanks for your reply an yes ive also got to hope tiger will fit in my car also so we both got the same probs
ATB chrisb
jonggd
  • The Fleet!
« Reply #47 on: May 15, 2023, 07:09:40 pm »
Continued with the detailing, and started on the Sea Viper missile silo.
In the Dockyard...
On the Slipway...
« Reply #48 on: May 15, 2023, 09:22:09 pm »
What excellent detailing your are achieving there John! I love how smart those hazard markings came out as well.
AdamG
« Reply #49 on: June 16, 2023, 09:39:35 pm »
Nice build John, any more progress?
Pages: 1 [2] 3   Go Up
Page created in 0.02 seconds with 20 queries.
