Author Topic: Another SUN !  (Read 1863 times)
KBIO
Another SUN !
« on: February 28, 2023, 05:32:58 pm »
Hi!
I knew that I was going to be in trouble, but I took the risk despite the prohibitive price of the Stuart brand which is quoted well on this side of the Channel ;  import taxes and other insurance, transport and so on on the other side!
The machine being there, I took pleasure in unjamming everything, dismantling everything before cleaning. I'm missing a part or two that I had to be able to machine down or to look after if necessary.
My biggest problem is the upper part of the cylinder head which is missing a part. Broken !
Maybe someone will have a spare one or an idea to fix it .... ?
Everything is dismantled and I have to drill the broken screws in the block that hold the lid. Not too much rust, a good sand papering will be enough.
Paint removal , ultra sounds, and I put everything back together !
KBIO
Re: Another SUN !
« Reply #1 on: March 03, 2023, 07:36:19 am »
Getting better! :-))
jonggd
  • The Fleet!
Re: Another SUN !
« Reply #2 on: March 03, 2023, 09:22:24 am »
Nice to see your rebuild is progressing nicely, what boat will you use the engine in?
In the Dockyard...
1/128 HMS Warspite - QE Class Battleship
1/72 HMS Campbeltown - T22 Class Frigate
1/72 HMS Apollo - T12I Leander Class Frigate
1/72 HMS York - T42 Batch 3 Destroyer
On the Slipway...
1/72 HMS Duncan - T45 Destroyer
KBIO
Re: Another SUN !
« Reply #3 on: March 03, 2023, 05:22:11 pm »
Good evening Jopnggd !
This engine is to replace the one I've put in a launch. First sail = first problem. solved now. :-))
https://youtu.be/lmsR4NpgcwI
I should be able to sail the launch as soon as the temp allows it.
In the mean time I found this one to restaure. Should be operational soon .... I hope !
Regards.
KBIO
Re: Another SUN !
« Reply #4 on: March 04, 2023, 05:05:03 pm »
Hello !
This is done ! It is getting better and gain some torque braking in. Need oil to gain efficiency and ready to go to the pub !  :-)
The oiler is done also !
I have a problem with the paint though !  O0
Now looking for another scrap to restaure  ! ..... if affordable !
Regards !
https://youtu.be/ajeRRVlKyTQ
DBS88
Re: Another SUN !
« Reply #5 on: March 05, 2023, 11:51:57 am »
Well done on completing a successful renovation looking forward to seeing it in the boat and running on the lake when the weather warms up
Page created in 0.168 seconds with 17 queries.
