Pages: 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14   Go Down
Author Topic: 1/96 Scale T26 HMS Belfast build  (Read 508133 times)
frogman3
Re: 1/96 Scale T26 HMS Belfast build
« Reply #50 on: June 20, 2023, 01:44:09 pm »
HI Dave lookin good what type an voltage are the motors you have bought ? an this is 1/96 scale isnt it ?
chrisb
T888
« Reply #51 on: June 20, 2023, 03:28:54 pm »
Hi Chris,
High Torque Mabuchi 555 DC Motor 9-30V purchased from Component shop.
Yes she is 1/96 scale length 1556mm x 220mm.
I’ll be running her on two 5000. mah NIMH  12v packs.
We have not finalised the final prop design, size, but it looks to be around 50-55mm dia five bladed.
Regards David
South Coast Modellers
frogman3
« Reply #52 on: June 20, 2023, 05:09:52 pm »
Hi Chris,
HI Dave wow 55 mm props will they be the scimitar type an she should look good an cheers for motor info but will see what i can get at wings an wheels this week end an if no joy then i have components shop catalouge will have a look at 4 motors from them
cheers hope it isnt to hot where you are
chrisb
T888
« Reply #53 on: June 23, 2023, 07:57:33 pm »
Photo showing the motor installed and the helicopter magnet track, which is installed under the flight deck and the hanger decking, this will allow the Merlin to move out of the hanger by a magnet and sail winch.
Regards David
T888
« Reply #54 on: July 30, 2023, 06:32:22 pm »
Quick update,
Started building the hanger and Mission bay. Detailing and layout is based on RN info currently available.
Regards David
frogman3
« Reply #55 on: July 31, 2023, 08:05:37 am »
HI Dave she lookin very good work on her an have you bought your 55mm props yet ?  as if you have i would love to see them as im still waiting for my 45mm props from prop shop
chrisb :-))
T888
« Reply #56 on: July 31, 2023, 09:05:29 am »
Hi Chris,
Thanks for your nice comments :-))
As for the props, no I’ve not ordered them as we don’t know what the actual design is ie blade shape, number of blades the only info we’re happy with is the dia.
The Major issue with this build is !! I’m building a model of the actual ship that is still be constructed and I’m having to wait for the RN to issue photos, info or if news agency publish build photos . Other than that I’ll have to make best assumptions, that later my require remaking.
But once it been sorted the I’ll post pictures.
Hope your props and revised motors help get Tiger working as you like :-)) :-))
Regards David
frogman3
« Reply #57 on: July 31, 2023, 10:26:32 am »
cheers Dave for the info an hope you get all your info when the r/n have her in commishion regards props an such  :-))
chrisb
T888
« Reply #58 on: August 04, 2023, 09:47:37 am »
Quick update.
Been working on the electrics. I’ve Completed the instal of the Forge Dist board and the main power loom. I still have to finish the radio loom. As for the electronics I’m awaiting delivery from ScaleWarship a Forge 8 way switch and a servo slow. Once I have these units , I can finalise the radio wiring and the wiring loom for the following,
Helio deck landing lights
Hanger and mission bay lights
Main radar
Nav lights
Bridge lighting
Setup the helio track sail winch.
Regards David
frogman3
« Reply #59 on: August 04, 2023, 12:07:32 pm »
HI Dave lookin very good layout an have you got treble 555 motors in an how big a magnet have you fittered in that tube to drag the chopper in an out of the hanger bay very good idea that an im still waiting for my bigger props for my tiger hope your knee is now better sir
All best to you an Andrea
 :-)) chrisb
T888
« Reply #60 on: August 04, 2023, 01:15:13 pm »
Hi Chris,
Thank I’m please with the track system, I’m looking at making the Merlin as there is no 1/96 or 1/100 scale kit available . I know the is a die cast 007 version, but that’s not an option at this time.
Yes the motors are 555, as for the magnets they are 10mm by 2mm 6kg strong.
Thanks for asking the knee is getting there. Hope your props arrive soon.
All the best to you and Jen
Regards David
« Reply #61 on: August 04, 2023, 04:13:46 pm »
Is the die cast merlin the necessary scale, if so, could moulding it and creating a multi piece vacuform version be an option ?
« Reply #62 on: August 04, 2023, 05:33:22 pm »
The build it as they build it technique is an exciting way to go isn't it! That should give you plenty of time to look for references and know that they will become available rather than 'were available but got binned, burnt, bombed, drawn over or lost back in the mists of time.
T888
« Reply #63 on: August 05, 2023, 10:11:25 am »
Hi Warspite
The die cast Merlin is the Italeri 1/100 scale Sky fall model. I could take a mould off this model, however I would modify the model from a HC3 to the Navy version.
Anyway it’s an option.
Regards David
T888
« Reply #64 on: August 05, 2023, 10:13:01 am »
Hi Ian,
I think your correct it would give me time to gain more updated info on the ship.
Regards David
T888
« Reply #65 on: August 14, 2023, 06:50:09 pm »
Hi Gents,
A couple of pics of progress to date.
Regards David
frogman3
« Reply #66 on: August 18, 2023, 02:54:59 pm »
HI Dave she's lookin good an that hole in the s/s is that where there will be a rib boat ? lookin forward to more pics sir
chrisb  :-))
T888
« Reply #67 on: August 18, 2023, 05:20:42 pm »
Hi Chris,
Thanks I’ve started on the Merlin build, As I can’t do much more on the S/S, as like your Tiger the internal workings, detailing has to be done before I put the hanger roof and the forward S/S there after I can then continue to build.
The large opening is for the mission bay the travers the beam of the ship.
Regards David
T888
« Reply #68 on: August 23, 2023, 07:57:47 am »
Made a start on some of the missile units on the Type 26 using photos of units fitted to up graded Type 45s and Type 23s
The first phot is of the Sea Ceptor system which provides complete protection against all known and projected air targets. The weapon system is now in full-scale development for the UK MOD as the principal air defence capability for the Royal Navy’sType 23 and Type 26 frigates.
The second is the master fitting and the mould I made.
Regards David
raflaunches
  • The Penguins are coming!!!
« Reply #69 on: August 23, 2023, 08:57:30 am »
Wow, they look the part! They look really different to the VLS caps used on the other systems. I must use my resin moulding kit I bought a few months back for this sort of thing.
Keep up the excellent work :-)
Nick B
Illegitimi non carborundum!
T888
« Reply #70 on: August 23, 2023, 09:07:44 am »
Thanks Nick,
I fully understand your work stress, as I’d had the same before I was promoted to Srn CE.(All work no play at that time).
Here is the second of the missed systems, the MK41 VLS, this is the same system used on the Arleigh Burke. So as I’d had the mould from USS Roosevelt this was a quick build. I’ve at this time not taken a mould as there is only one of these on the Type 26s
Regards David
frogman3
« Reply #71 on: August 23, 2023, 01:44:24 pm »
HI Dave lookin very good them VLS hatches an what missles will be in there
chrisb
T888
« Reply #72 on: August 23, 2023, 02:16:25 pm »
Hi Chris,
At this time based on Defence News BAE system have got in to bed with Lockheed Martin to use the MK41 system
“The British have yet to publicly specify the missile types to be deployed in the Mk 41, but the launcher system has the flexibility to simultaneously operate anti-surface, land-attack, anti-air and anti-submarine weapons.”
Regards David
frogman3
« Reply #73 on: August 23, 2023, 05:34:12 pm »
 :-)) OK DAVE
CHRISB
T888
« Reply #74 on: August 27, 2023, 03:55:47 pm »
Over the last few days started on the massive funnel on the Type 26, detailing will be added once more RN info, photos become advavlable.
Regards David
Pages: 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14   Go Up
Page created in 0.017 seconds with 20 queries.
