Author Topic: boiler bush  (Read 2238 times)
pipercub1772
boiler bush
« on: March 22, 2023, 04:32:24 pm »
Hi I've run into trouble with a cheddar boiler ,bottom water gauge sheered off its 1/4x32 tried the usual heat and stud extractor no joy ,drilled 5 mll and taped 1/4 32 but fitting sloppy in boiler bush  ,I'm thinking trying 5 1/6tap which i have but unsure of the drill size i need to use any thoughts there is plenty of meet on the bush itself ,kind regards Allan
ddmckee54
Re: boiler bush
« Reply #1 on: March 22, 2023, 05:59:57 pm »
Here's a link to a German site listing the model engineering thread tap drill sizes.  They don't say what % the thread depth is though, maybe 60%?  If you're metrically challenged, there are plenty of on-line converters that will change mm to inches.
https://www.gewinde-normen.de/en/me-thread.html
Too many irons, not enough fire.
Ralf
Re: boiler bush
« Reply #2 on: March 22, 2023, 06:16:05 pm »
try to drill out from 4mm to 5,5mm and then try to get out the broken water gauge. Recut the thread if necessasary.
Much luck
Regards Ralf
Re: boiler bush
« Reply #3 on: March 22, 2023, 06:52:40 pm »
What is the pitch, ie, ME, BSP, BSB'  whit worth, etc as I have all the tapping size gauges
pipercub1772
Re: boiler bush
« Reply #4 on: March 22, 2023, 07:16:42 pm »
i think its me thread i think its what cheddar used unless anyone knows for sure thanks for all replies
Ralf
Re: boiler bush
« Reply #5 on: March 22, 2023, 08:36:55 pm »
Cheddar boiler bushes are 1/4X32TPI Model-Engineer
Ralf
pipercub1772
Re: boiler bush
« Reply #6 on: March 23, 2023, 08:02:06 am »
thanks I've sorted it drilled both water gauge bushes 7 mll and taped out 5 1/6 x 32 waiting for water gauge from kennions thanks for all  replies
regards Allan
Re: boiler bush
« Reply #7 on: March 23, 2023, 06:16:18 pm »
Glad you have got it sorted  :-))
CliffW
Re: boiler bush
« Reply #8 on: March 25, 2023, 12:58:13 am »
Allan, going to the larger 5 1/16x32 ME fitting should work fine...if memory serves correctly the bush will have plenty of material for tapping to the larger size.
pipercub1772
Re: boiler bush
« Reply #9 on: March 25, 2023, 04:22:11 pm »
thanks for the reply as you say plenty material for the larger size ,regards .
Page created in 0.046 seconds with 17 queries.
