Author Topic: Cutting piano wire  (Read 4175 times)
sinjon
  • Sinjon
  • Model Bioat Mayhem Forum is the Best!
Cutting piano wire
« on: November 05, 2007, 01:59:07 pm »
Is there way of cutting piano wire without 'nicking' my pliers or Gilbow tin snips?
Or is it just a question of buying a really good pair of side cutting pliers.
FullLeatherJacket
Re: Cutting piano wire
« Reply #1 on: November 05, 2007, 02:56:32 pm »
I have a pair of Maun Industries' side-cutters which are sold to snip those steel pins that surgeons fit into broken bones. Had 'em for years with no trace of a nick in the edge. Google Maun Industries and see what you can find - maybe Squires sell them? Anything thicker than 14SWG is a job for bolt-croppers or a diamond cutting wheel / saw blade.
FLJ
wingertaz
« Reply #2 on: November 05, 2007, 03:12:26 pm »
    I use carbon cut off wheels in my mini drill. Carefull though they are very brittle. I break more than i wear out. :(
« Reply #3 on: November 05, 2007, 06:10:08 pm »
Search E bay for a pair of SNAP ON side cutters these will cut anything and when they don't just contact Snap On cos they guaranteed for life
Bryan Young
« Reply #4 on: November 05, 2007, 06:34:34 pm »
I have this little gizmo that is basically a pair of pliers with 2 holes in the arms. One hole above the pivot bolt and the other below.
The holes are never "quite right" but they chop piano wire dead easy. The chopping does leave a little "hook" on the cut end, but this is removed in a couple of seconds with a small sanding disc. I'm pretty sure that most model shops will sell them ( pretty cheap), but the "Hobbies" magazine still has them (I think). A good buy.
Notes from a simple seaman
BobF
« Reply #5 on: November 06, 2007, 07:01:46 pm »
Hi sinjon,
I use a cold cheisel against a small anvil for thicker wire, then bend it with pliers and it snaps in two.
Or a mini cutting disc.
sinjon
  • Sinjon
« Reply #6 on: November 07, 2007, 08:37:33 am »
Spoilt for choice!
Thanks guys
Bee
« Reply #7 on: November 17, 2007, 12:08:11 am »
No one mentioned junior hacksaw. The blades are harder than full size hacksaw so will cut almost anything. For the thin stuff drill a suitable hole through a bit of wood , insert wire, cut through both.
SimonO
« Reply #8 on: November 17, 2007, 04:55:35 pm »
Get a cheap lighter, warm up the area you want to cut let it cool and it will cut without damage, You just have to temper it a little more. Or nick it with a file edge and it will break.
Simon
Page created in 0.037 seconds with 21 queries.
