Author Topic: gorrilla glue  (Read 2962 times)
Trucker
gorrilla glue
« on: June 07, 2023, 07:29:32 pm »
Hi, All
Has any one found a De- Bonder for the clear gorrilla glue, ive used some to secure my outer brass shaft tubes into a square abs tube which passes through the wooded hull, but , i need to adjust them but it rock solid, ive tried super glue de bonder but no luck,
TRucker
Andyn
Re: gorrilla glue
« Reply #1 on: June 07, 2023, 07:43:44 pm »
By clear Gorilla glue do you mean Gorilla epoxy? If so, there isn’t a debonder for it. Don’t think there is for regular gorilla expanding glue either.
Heat (via a heat gun or similar) will loosen the epoxy enough to remove the tube, then it’ll be power tools to remove the rest
Trucker
Re: gorrilla glue
« Reply #2 on: June 08, 2023, 07:22:03 am »
Thanks for your reply, it's not the two part epoxy, it says clear on the bottle, I tried a heat gun last night but was concerned it was going to melt the surrounding plastic, guessing there isn't a debonder so went for drastic measures and got the Dremel out, and trimmed off 3mm of the shaft tube which then allowed the prop to better positioned within the kortz.
Trucker
Page created in 0.013 seconds with 20 queries.
