A (final ?) update on both boats then ..
The No 1 boat is repaired in as much as I was able to join the coupler together again and I managed to straighten the prop shaft to where it is about 99% true (you can learn a lot watching 'The Repair Shop') ..
and it ran very well on a test late afternoon today, I will of course still get a new prop shaft and coupler though .. !!
The No 2 boat was running well as said in an earlier post, albeit with a tendency to drift to port, a nice turn of speed (not as fast as the No 1 boat) and it responded OK to rudder commands, however in as much as the original boats had three engines, props etc all turning the same way, I have taken off the 40mm contra props, reversed the stbd engine polarity again and re fitted the standard 35mm props with both turning anti clockwise, it runs well on the stand but has yet to be tested on water, all in all though I don't expect any problems.
Going back to page one of this I have, Im pleased to say, come along way with the No 1 boat and what it was like originally to get to what it is today and learnt a lot in doing so thanks to help and advice here from those that gave it ... I bought the No 2 boat as a slightly started kit with a view to completing it and applying what I had learnt from the No 1 boat, ultimately to sell that one ... however given the state of the No 1 boat and all I have put into it plus its performance capabilities, Im probably going to keep it and sell the No 2 boat ... but not before I can get some stills and videos of a two boat patrol on the water, which I think .. Im hoping .. will look good
I will add pics as and when .. and perhaps if .. I manage to do that !
