November 13, 2025, 03:16:58 am
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
The Shipyard ( Dry Dock ): Builds & Questions
Submarines
air pump
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: air pump (Read 3887 times)
B DAVIES
Guest
air pump
on:
November 06, 2007, 03:57:13 pm »
I am rebuilding the U570 by Darnell Models, what I would like to know is if any one out there knows if I can get a air compressor
to fit in the box .I have the old steam engine piston type but its slow and would like to change it .
Help please
Brian
Administrator
Full Mayhemer
Online
Peterborough, UK
Re: air pump
Reply #1 on:
November 06, 2007, 04:49:42 pm »
The old air pump system are quite power hungry.
I converted my Darnell to a Freon system using a small tin of air brush propellant and a micro Festo pneumatic valve.
Giant Models
Full Mayhemer
Offline
Middlesex
Re: air pump
Reply #2 on:
November 06, 2007, 06:36:34 pm »
Buy 1 off those cheapy portable tyre pumps and remove the guts, if you want to run 6v's
then best replace the 12v motor.
Administrator
Full Mayhemer
Online
Peterborough, UK
Re: air pump
Reply #3 on:
November 06, 2007, 08:53:51 pm »
I tried that Andy, the current draw was about 8 Amps!
What motor and gearing did you use?
Giant Models
Subculture
Full Mayhemer
Offline
North London
Re: air pump
Reply #4 on:
November 07, 2007, 09:43:55 am »
Have a look here-
http://www.respotec.de/shop/start.htm?motore_pumpen_ventile_luefter_pumpen.htm
The thomas pumps are diaphragm based, so zero maintenance. They will clear your tank in seconds, draw minimal current(high quality Buhler motor), balanced, cheap. Won't pump high pressure though, so if you want to run over 20psi, you'll need to look for a piston compressor.
Smart products also do a similar line in air pumps, however I don't think they will sell in single quantites now.
http://www.smartproducts.com/pumps_series_8000_air_pumps.php
kazzer
Guest
Re: air pump
Reply #5 on:
February 11, 2008, 05:06:03 am »
I have some neat air compressors, pretty powerful and small. They have TWO pipe connectors, unlike the Smart pump - much easier to connect up.
Have a look at
http://www.caswellplating.com/models/pumps.html
Also have a positive gear pump for water and several neat switches see
http://www.caswellplating.com/models/bhm.html
We can mail this stuff to the UK too.
Capricorn
Guest
Re: air pump
Reply #6 on:
March 09, 2008, 12:35:03 am »
Are air pumps much different than air compressors? Higher volume maybe? Just for comparison I got this very cheap air compressor from an auto parts store (napa) here in the US for about $15, it's cheap to be sure and laughable that it is sold to pump up auto tires from a car battery, it would take several hours at least. Anyway, they make them cheap, it's an option if it works for you:
Print
Pages: [
1
Go Up
« previous
next »
Submarines
air pump
