Author Topic: JJC Electronics connection help  (Read 3083 times)
NigelW
« on: August 07, 2023, 08:57:21 am »
Morning All,
I have a very old JJC electronics master and slave module and an unreadable image of a connection diagram which I found on here (resolution too low to make any sense of).
I understand that the unit is still working but I'm keen to avoid damaging it. If any one can share a readable copy of the connection diagram to the green terminal block I'd be grateful.
Nigel
Re: JJC Electronics connection help
« Reply #1 on: August 07, 2023, 09:54:32 am »
1. What units do you have ... model No.?
2. aby chance of a couple of photos?    :-))
NigelW
« Reply #2 on: August 07, 2023, 10:03:48 am »
Hi Martin,
I have a JJC 304 Master and a 310 slave. The 304 sound on the master is I think a gas turbine. It's the 310 sound on the slave I'm interested in which I believe is the turbocat. Guessing I can just connect this via a 3.5mm lead, or potentially remove the heatshrink and swap the 310 chip across to the master. It's the connections on the green terminal block I'm not sure of. 2 of these are obviously for the speaker and I assume the other 2 for the power input. I plan to run the speaker via an old Maplin 12w amp.
NigelW
« Reply #3 on: August 07, 2023, 10:07:49 am »
I've attached a couple of images of the 304 and 310 sound units
NigelW
« Reply #4 on: August 07, 2023, 10:09:45 am »
And this is the diagram I'd like to get in a readable resolution
Stan
« Reply #5 on: August 07, 2023, 10:40:27 am »
I hope you can get the info you need. It is a long time since these units disappeared of the scene and the late production models were not very good. Please note I am not saying your units will not function just making you aware there is no back service for these units should they fail. Good luck with your search.
Stan.
NigelW
« Reply #6 on: August 07, 2023, 10:44:39 am »
Thanks for the reply Stan.
I know it's a long shot and that they're a little flakey from a cooling point of view so will tread carefully and add a fan assuming I can get them working. They were ahead of their time in terms of sound quality, and with the Action Electronics Noisy Thing no longer available it's a shame really. It's for a Dutch Courage that has been in build for over 12 years (!).
Anyway, fingers crossed and I'll report back.
All the best,
Nigel
mrlownotes
« Reply #7 on: August 07, 2023, 02:24:16 pm »
Nigel
I have a JJC installation and Setup sheet.
Do you have an email address I can send some scans to?
PM me your email, to keep it secure.
N.B. You can run the master unit on 6 to 18 volts which gives an output of up to 15 Watts through an 8 ohm speaker.
Cheap 4 ohm speakers are not recommended.
The chip under the heatsink is a 15 Watt audio amplifier.
I ran one, with an attached slave unit on a 12 Volt NiMH and later on a 4S Lipo (16.8 Volt).
I had to eventually add a 5 Volt minifan blowing across the heat sink due to the chip overheating and cutting out.
Bintur Ellenbach
mrlownotes
« Reply #8 on: August 07, 2023, 03:59:03 pm »
Nigel......email sent.
Good luck with your installation.
Bintur Ellenbach
NigelW
« Reply #9 on: August 07, 2023, 04:01:50 pm »
Many thanks for all the info Alan. Very grateful.
Umi_Ryuzuki
    • Models and Miniatures
« Reply #10 on: August 07, 2023, 07:03:13 pm »
Didn't we re-scan these JJC sound instructions recently?
NigelW
« Reply #11 on: August 14, 2023, 07:44:58 am »
Many thanks for the info. I'm pleased to report that it's all up and running perfectly with the turbocat slave model. No external amplifier fitted but a small PC fan blowing cool air on the amp chip heat sink. A tip to anyone using an 8W 4Ohm speaker - attaching a cut down closed ended pringles tube gives a far deeper sound.
« Reply #12 on: August 14, 2023, 04:58:37 pm »
