Author Topic: Amati Dorade build and conversion to RC  (Read 9333 times)
smileyjon
« on: August 10, 2023, 10:10:10 pm »
So after building the Model Slipways Bluenose some years back (see elsewhere on this site) I'm going to 'try' and build the Amati Dorade with the intention of adding RC for pond sailing on occasional nice days . . .
I'm way out of my depth and looking for any help and input so here we go . . day one !
I've worked out the approximate waterline (poorly illustrated on the plans) and built a small test tank to work out where the lead in the keel might go and how much is needed.
I'm increasing the rudder size and I desperately wish to avoid a removable deck as this is primarily a display model.
I know almost nothing about RC stuff but need to keep this very reliable and simple . . and space is limited as she is only about 900mm long and 160mm wide with 3 sails to control.
I'm going to try and add a sketch of how I 'think' this would work . . please comment and offer guidance !
Thank you all
Jon
roycv
Re: Amati Dorade build and conversion to RC
« Reply #1 on: August 11, 2023, 12:05:21 pm »
Hi good luck with the build.
Have you considered using a winch with an encapsulated drum?  I have a yacht of dorade's size that works well with the winch.  You do not need a loop to go with it.  The sheets to the main and jib come out direct to the sails.
They are in a standard size servo and need careful setting up but once done no problems.
Howes sell them for about £10 with some options on the number of turns, 4 should suit you.
Keep going
Roy
roycv
« Reply #2 on: August 11, 2023, 12:30:37 pm »
Hi this is a top view of my compact winch and rudder control.  The rudder control was a surface system on a pond yacht.
roycv
« Reply #3 on: August 11, 2023, 12:33:23 pm »
Here is a view of my compact set up.
Roy
smileyjon
« Reply #4 on: August 11, 2023, 07:00:10 pm »
Many thanks Roy . . show more sometime please as it looks amazing and I will look into the winch idea !
I would like (if possible) to build this primarily as a display model (proof of the pudding etc) and try to hide as much as possible.
There is one on this site which has full RC but has a full removable deck . . and of course QD rigging and so-fourth.
My current (today) plan is to have just the mid section as removable thereby keeping much of the rigging untouched. Front of cabin to rear of cockpit perhaps . . .
I'll post a pic of interior held in place with tape . . although yet again the image upload failed and all was lost . . tried copy/paste, the insert image icon and the add image link . . . . . bogger !
Thanks again
Jon
smileyjon
« Reply #5 on: August 11, 2023, 08:43:20 pm »
mrzippy
« Reply #6 on: August 12, 2023, 09:34:32 am »
Hi Jon,
I've spotted a removable deck version (with 2 drum winches) on 'RC Groups' and personally would avoid it,
sounds like you are on the right track with your much simpler mid section hatch idea.
Dorade's internal structure brings back memories of helping a friend build a Nottingham J class yacht kit,
you may find their build instructions and winch details helpful -
https://docs.google.com/document/d/1YbkIU_OPtht3Ns8gDNtOYmQmuOz5lYFH/edit.
Their winch builds up into a single unit around an Aluminium bar with pulley at one end and motor at the other,
the complete unit drops in at a shallow angle via a hatch and is removable for maintanance etc.
Gary Webb's 'Bearospace Industries' schooner models from the USA also have similar winch systems with lots of pics and info online.
https://www-minisail--classic-de.translate.goog/minisail-classic/flotte/?pageId4b2d4cc0=3&_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=en&_x_tr_pto=sc#list_4b2d4cc0
I wish you good luck it is a beautiful design and deserves to be on the water !
Paul.
roycv
« Reply #7 on: August 12, 2023, 03:44:05 pm »
Hi Smiley...  Here is a photo of my pond yacht 32 inches long.
Roy
roycv
« Reply #8 on: August 12, 2023, 03:47:06 pm »
Anyone who has built the Aeronaut Bella kit would recognise the sails as these are from the kit.  I rebuilt my Bella as a gaff rig, the sails were left over.
Roy
smileyjon
« Reply #9 on: August 12, 2023, 05:22:45 pm »
Lovely . . . great sails
Roll of lead arrived today so into the test tank in the week . . lots of calcs
Still looking at the deck and wondering HOW to have a longish lift off section when planks are curved.  It'll come to me !
Forming an oversize rudder and a stand today
No pics as yet
Jon
smileyjon
« Reply #10 on: August 12, 2023, 08:34:42 pm »
Paul . . .  many many thanks for the links
Off to investigate them right now !
Tomorrow I begin on the internal framing . . not quite as per supplied plan as I intend to leave out one cross part and amend the floors a little.  Erring on the side of caution as it's easier to add than subtract
For now thanks again
Jon
mrzippy
« Reply #11 on: August 13, 2023, 09:37:27 am »
Hi Jon,
You may be able to get away with a hatch under the main cabin and footwell area only - along the lines of a Notts J -
here the winch units forward pulley end slides into a location hole out of sight under the deck and held by screws in the cabin area,
all works without hacking hatches in the deck etc, admittedly it's a much bigger model with acres of room but with some experimentation it could work.
Roy I know little about drum winches being used as they are intended (hauling in main sheets),
my yachts to date use the above drum/loop hack or servo lever arm style -
Any thoughts on how Dorades 3 sails would work - can 3 sheets operate from a single drum winch??
I've noticed the removable deck Dorade uses 2 drum winches -
https://www.youtube.com/watch?v=F2xoqrNHkZQ
Paul.
smileyjon
« Reply #12 on: August 13, 2023, 09:08:06 pm »
Many thanks Paul . . all taken on board so to speak but my understanding of winches is zero . . but I have ideas and I'll run them past you, and anyone else who can help.
Build a moc-up of the space and possible access points (as suggested) and hatch openings . . . find what might be the best winch for the job (no idea), plus some kind of nylon thread, plus pulleys or tensioners etc and play around . . before affixing the deck or the hull framework.
The frames themselves limit the idea of feeding in a part built assembly (I tried it)
Another idea when the above is done is to begin laying the darned curved deck planking (the Bluenose deck for part curved part straight)
until the planking begins to reach the main deckhouse . . see sketch
Just thoughts
Just looked closely at all the parts . . am I scared.  Yup !
mrzippy
« Reply #13 on: August 14, 2023, 08:58:01 am »
Yes with you Jon the slow steady approach will win out and be well worth it in the end !
Curved planking is going to be an interesting challenge - I have cut hatches in between planks (where black caulking normally goes)
after a deck is complete, it was nerve-racking using my favourite tool a scalpel, end result works well you hardly notice the join -
just takes an age, a steady hand and lots of new blades !!
Recently discovered 'Olfa' 30 degree Snap-Off knives with incredibly sharp blades which are stronger and stay sharper than 10A scalpel,
plus less fiddly than swapping surgical blades - one of these would work well cutting 'what is likely to be the most important cut on the entire model'. Lol.
Paul.
smileyjon
« Reply #14 on: August 14, 2023, 08:29:23 pm »
Thank you Mr Zippy
I may moc up a test area first . . and I too use a 10A scalpel
Jon
smileyjon
« Reply #15 on: August 14, 2023, 08:35:28 pm »
Thoughts and ideas from a novice . . . .
Would this rubbish sketch have any chance of working.
Bear in mind this is hopefully going to become primarily a display item and if a couple of days each year this Norfolk wind subsides and she floats, stays kinda upright and kinda 'sails' . . I'll be very content.  This is a old gentleman's pond yacht !
smileyjon
« Reply #16 on: August 15, 2023, 12:50:08 pm »
Food for thought (even more)
Ballast
I've done a very rough tank test and I'm wondering if a deeper weighted removable keel may be an option . . .
She has quite a lot of 'stuff' above the waterline, weighing in at near on a kilo, with lead ballast inside she its too low in the water for my liking . . too little ballast and she's somewhat unstable . . and I need to avoid water ingress . . . so . . .
what if I cast a couple of captive nuts (in resin) inside the bottom 'fin' of the keel.  The 2 small holes would not be visible when the boat is on display and I could then mess about with trim, depth of add-on keel and weight after the model is built.
Your 'expert' thoughts please . . . with a cherry on the top of course  :}
Jon
mrzippy
« Reply #17 on: August 15, 2023, 01:23:19 pm »
Good thinking - the lower the weight the better ! and potentially less required to create the same effect.
I've watched the removable deck versions video in detail and now thinking his two winches are only controlling the main and jib,
the rear mizzen? looks to be doing its own thing - a slight cop out in my view, Gary Webbs 2 masted models all seem to sail very well.
Paul
smileyjon
« Reply #18 on: August 15, 2023, 04:27:52 pm »
Many thanks Paul . . seems to be the way to go eh !
I'd like the mizzen to also work, purely for aesthetics . . . can they all 'play out' on the same side . . if so I'll need about 300mm of cable movement off the drum winch (I need simplicity as first RC build)
Next bit of advice for all . . . what's a good starter kit for the RC stuff.  I think I need a transmitter and receiver . . a double spooled winch (spool diameter and rotation to length required ratio ?) and some batteries, and a steering server.
Also something to link the steering server to the rudder top, and a reliable idler pulley and spring . . . . . and where does the aerial go ?
It'll be easier to install these bits early on as long as I can 'just' get to them as needed later
Jon
smileyjon
« Reply #19 on: August 16, 2023, 08:37:22 pm »
Water outlets rough formed c/o Mr Dremel and a metal strip clamped at the appropriate datum . . and the very beginnings of the cabin thing (50 more parts to complete this bit).
The rough looking hull is where the masking tape pulled the protective film away.
The many blocks are horribly tiny and each comprise 7 or more parts . . how I'd love to find some ready-made . . . .
I'm going to slowly build all the tiny deck bits while trying to source info on the r/c stuff.
I think the next job will be to fabricate a stand to hold the thing upright during the build !
smileyjon
« Reply #20 on: August 18, 2023, 03:48:14 pm »
Well then . .
I've taken the plunge and ordered a basic radio set, a steering servo and a 2 turn winch servo which will give me about 160mm of travel for the sails.  This suits the mizzen, almost suits the jib but it'll mean hooking the sheet to the mainsail about 160mm from the mast . . I do hope this works.
I'm making  s l o w  progress with the deck fittings . . . bought a tiller thingy and rudder rod, test trying a 'planked hatch cover (mmm . .) and spending ages sanding of the burnt edges of everything . . hey ho !
smileyjon
« Reply #21 on: August 21, 2023, 09:47:40 pm »
Not much to show as yet, perhaps in a day or two . .
For now the 12 timber parts of the mainmast have been put together and rough sanded . . . and because I want to make an access through the deck I've made a rig that follows the curves of the frames and I'll clamp the deck down onto this and build it there . . then later I'll drop the framing assembly and R/C stuff into the hull in one piece, cut the access in the deck and finish the planking and finally glue this onto the framework.  There are several other considerations during this and I'll detail this as and when.
See y'all soon with pics hopefully !
smileyjon
« Reply #22 on: August 26, 2023, 10:35:19 am »
Updates . . .
I have decided (r or w) to sit the deck on a rig as there will need to be some cutting for R/C access and test holes for the sheets.
This will be test fitted into the hull at various stages to ensure all is well.
I also have to consider strengthening the chain plates etc to take the higher stress load
The deck will be then roughly fixed to the framework and the working parts installed and tested prior to finally fitting the framework into the hull and adding the pre-planked deck . .
I have no idea as yet how the R?C unit works.  I have 2 and 4 turn sheet winches, a steering servo, transmitter with matched receiver . . but I assume the receiver needs a power supply.  No idea.  Help please !
The strips along the center of the deck are sanded and primed (not stained as too irregular looking) . . after the deck is sanded I will have to carefully add an appropriate colour (laugh) . . and there is a minor length issue at the bow with needed some fiddling !
Two rows of outside planking are being added now (pic) . . inner row is un-glued so don't panic.
Sheesh !
smileyjon
« Reply #23 on: August 26, 2023, 10:38:04 am »
Stuff . .  help please . .
smileyjon
« Reply #24 on: August 26, 2023, 10:39:31 am »
The rig follows the actual framing profile . .
