Hi Bill,
What is the model number of the Mtroniks ESC?
Does the ESC need setting up/configuring (Easy one touch set up)? - In Mtroniks speak - Calibrating the ESC to your transmitter....
C-3PO
Example for Viper ESC
ESC SET-UP
Before beginning set-up you need to connect up your VIPER ESC as in Fig.1.(When plugging the ESC’s receiver lead into the receiver make sure that the signal wire - orange - is facing inwards).Calibrating the ESC to your transmitter Now that you have installed your VIPER ESC in your model you need to set the ESC so that it responds to your transmitter.
1. Switch on your transmitter and ensure the throttle control and throttle trim are in the neutral position.
2. Plug your VIPER ESC into your battery pack and turn the ESC on with on/off switch. (The red & green LED’s will flash for 2 seconds - This is the set-up window, if you press the button whilst the LED’s are flashing you enter set-up, if you let the LED’s flash for 2 seconds then stop, the ESC will operate with previously input set up values.)
NOTE2: If LED’s do not flash but instead there is a solid red LED this indicates no signal, checktransmitter is turned on & that the receiver lead iscorrectly plugged into the receiver.
3. Whilst the LED’s are still flashing, press theset button, this will set your neutral position, thegreen LED will come on.
4. Push the throttle control to the full forwardposition and return to the neutral position, (Thishas set maximum forward speed point) the redLED will come on.
5. Pull the throttle control to the fullreverse/astern position and return to the neutralposition. (This has set the maximumbrake/reverse/astern point)
Calibration is complete
