Author Topic: ELCO 80ft P T BOAT TEST RUN  (Read 1810 times)
Dean's Marine
    • Dean's Marine
« on: February 18, 2024, 04:28:23 pm »
 Hi All Test run for the kit of the ELCO 80ft P T boat a cold blustery day and the lake level was very high, we had been waiting a long time for some decent weather to test run her  it was brilliant sunshine . Kit is to 1/24th scale powered by 2 falcon 5 motors running on 3800 6v nicads on 32,5 mm nylon props. THE MODEL KIT L 1.05m x B 280mm The hull of this model is moulded in lightweight glassfibre, with a moulded in rubbing strip that forms a seating for the 1.5mm LASER CUT PLASTIC deck. The bridge and aft superstructure is a one piece glass fibre moulding and all deck and structure parts are in laser cut 1mm H.I.P.S. plastic. To complement this most attractive model a full set of fittings in cast metal and resin is included along with propeller shafts, tubes and rudders. To assist in the construction a FULL SIZE PLAN is provided along with a complete set of comprehensive instructions, A c/d of all the pictures taken during assembly of the prototype model plus a set of decals to give a colourful finished model. As in all of the Deans range, the on the water performance is outstanding. see her  on you tube https://www.youtube.com/watch?v=DUQPrYMlPnQ   Regards Deans marine
Page created in 0.035 seconds with 21 queries.
