Author Topic: Hobbywing 1060 speed controller  (Read 2838 times)
terry1956
« on: February 25, 2024, 12:10:54 pm »
Hi, I thinking have made a mistake in buying the hobbywing 1060 speed controller. In the manual it states that the speed controller works with Li-po and nimh batterys. So what will happy if I contacted a 12v lead acid battery. Will it blow up or will it run? Anyone know.
chas
Re: Hobbywing 1060 speed controller
« Reply #1 on: February 25, 2024, 12:20:48 pm »
A 3s lipo fully charged is 12.6 volts, and the 1060 is rated for that. A fully charged 12 volt lead acid will be a little more than that but I'm sure that it will be ok, the discharge curve of the two types is quite different and a lead acid battery drops voltage quite quickly. I'd be astonished if you had a problem using it.
Chas
SailorGreg
« Reply #2 on: February 25, 2024, 01:12:24 pm »
Yeah, what Chas said.  When the volts arrive at the ESC they just look like volts, whatever the chemistry used to produce them.  You will get different run times, but you won't damage anything.
Greg
terry1956
« Reply #3 on: February 25, 2024, 02:15:01 pm »
Thanks chaps
Detomo
  • Model Boat Mayhem Forum is Great!
« Reply #5 on: March 11, 2025, 03:20:39 pm »
Hi Peeps, I have a 1060, it won't turn the motor. The red light comes on put now it just flashes, as push to go forward it clocks it put nothing is happening the rudder works fine.
Any ideas, or is it Knacked ??? >>:-( >:-o
Detomo
« Reply #6 on: March 11, 2025, 03:32:39 pm »
By the way it's on a club 500 using NIMH 3000 batteries :((
Umi_Ryuzuki
    • Models and Miniatures
« Reply #7 on: March 11, 2025, 04:20:49 pm »
Usually the ESC is looking to be set, or is waiting for the throttle stick to be put in the neutral position.This sometimes happens on my jet boat, and it I can never remember the steps... LoL
Dave_S.
  • Member of Oxford Model Boat Club
« Reply #8 on: March 11, 2025, 06:25:19 pm »
It might be in set-up mode - I have a couple of these ESCs in use and they work well once set up. You should have a copy of the instructions for setting it up in the box it came in, if not, I can copy them for you. My understanding is that these are primarily aimed at the R/C car market, but they do work on boats too.
Ruining perfectly good kits since 1969.
Detomo
« Reply #9 on: March 12, 2025, 09:02:37 am »
Cheers guys, shall try and reboot  :-)) and then see what happens  :embarrassed:
Page created in 0.107 seconds with 21 queries.
