Built one around 6 or 7 years ago, 36 inches by 12 inches bed to allow for cutting balsa sheet for aircraft. Uses 2 steppers for the y axis and one for the x, I bought proper stepper drivers as I used large steppers and the controller came from China and is the same as used in some of the smaller commercial cutters. This allows for the use of some decent software to import dxf files and place them to maximise the use of the wood. I did fit an 80W CO2 infra red laser and this is supposed to be the output wattage not just the input, probably less as the Chinese tubes tend to give too high figures. For some good info on laser cutters check out the long running series on You Tube by SarbarMultimedia in some of his earlier ones he showed how to measure the laser output just using a measured volume of water and a thermometer, he found his supposed 60W tube was actually putting out around 45W. You can buy a proper measuring device to find out the laser wattage, it uses a blackened plate and the temperature rise in a set time.
Jim
