Author Topic: Wood infused filament...  (Read 1470 times)
DJW
« on: April 08, 2024, 05:57:38 pm »
Hi All
I have some tricky wooden pieces to produce for my Aquarama build, for example a grating in the cabin, or a rattan magazine holder for back of seats.  Could be done but not really seen and would take a lot of time. And I thought why not try 3D printing the parts, then paint them, and discounted the idea almost immediately as a particularly bad idea.  But then found I can actually source wood infused filament, like this...
https://www.123-3d.co.uk/123-3D-mahogany-wood-PLA-filament-1-75mm-0-5kg-i1536-t26973.html
Question is, has anyone tried this or any similar filament..?  I'm wondering how it really behaves.  I'm using a Creality K1C.
Best regards to all.
David.
tica
    • Skalamodelskibe
Re: Wood infused filament...
« Reply #1 on: April 08, 2024, 07:05:26 pm »
I have printed with Wood PLA on my Ender 3V2, follow suppliers recommendations and it works best with a 0-6mm nozzle.  A 0.4mm tends to clog easy.
My postings are only reflecting my own opinion and should not be read as the holy grail of truth :-)
DJW
« Reply #2 on: April 09, 2024, 09:52:04 am »
Morning Tica
Thanks for your comments.  I've just found out that Creality have released a nozzle set of 0.4, 0.6 and 0.8mm for the K1C, so I'll get a set and some of the filament to try.  Do you have any comments on whether it looks like wood when printed, or takes varnish..?
David.
tica
    • Skalamodelskibe
« Reply #3 on: April 09, 2024, 11:12:49 am »
This is one of the items I have printed with a wood filament (not the one you have linked to) have not tried to add varnish to it.
DJW
« Reply #4 on: May 10, 2024, 11:41:12 am »
Hi Tica
Thanks for posting the pic.  I've had mixed results so far.  I couldn't source the mahogany infused filament I mentioned, waiting for it to come back into stock. I tried the eSun Wood filament, and while it does sand better than normal PLA, it's really light in colour so not ideal for my purposes.  I'll play around with it a bit more and try staining it to see what happens.  In the end I just used the print as a template then faced my part in mahogany veneer and used the accuracy of the 3D print to drill then chisel / file into a grid.
And the result:
Should be fine once sealed and finished.
So a fail for 3D printed wood, but I haven't given up yet.
David.
