Author Topic: Complete beginner to steam has steam plant question for Thames launch project  (Read 6083 times)
TomF
    • 1 of 1 stuff
I am reaching out to all of you Steam experts to help me answer a few questions that I can't find answers to either on this forum or the larger internet
My knowledge of steam is limited to boiling a kettle, but have taken the plunge and bought a Microcosm M30 steam plant as shown and a 49-inch glass fibre hull to make a Thames launch-style boat.
Screenshot-2024-04-15-083707.png" border="0
My questions are as follows.
Tap water, ionised water or pond water and water tanks.
  • I have read some conflicting information about the use of tap water (scaling the boiler for example) but what about pond water after all there is plenty of it when running the boat! If it looks clean can it be used, perhaps running it through a paper filter first?
  • I can see the advantage of a separate water tank versus filling the boiler directly, but can the boiler be topped up while it is still hot, then what about the pressure inside the boiler would a hand pump overcome the pressure or would an automatic/electric pump be better?
  • I have seen water tanks being formed in the bow of the boat, which seems like a good use of space. Do the tanks need venting to let air in? Do you need to fit a stop cock between a hand pump and boiler or are the hand pumps good enough to withstand boiler pressure?
Gas tanks
  • Can gas tanks be lagged (for cosmetic reasons) like the boiler or is it best to leave it as is?
  • Is it advisable/sensible that gas tanks should be filled outside the boat?
  • Should a gas regulator/cutoff be fitted in case you need to turn off the boiler remotely - if so what are the options?
Condensor tank
  • Same question as the gas tank - is it OK to lag?
  • Can I exit the steam into the boiler chimney, or is it best to leave a pipe running up the side of the chimney?
Electronics
  • I see it is possible to fit pressure sensors, water level sensors, ECU, GCU etc - would any or all of these be useful/desirable?
  • Are there any telemetry options that could signal any potential issues to the transmitter?
No doubt will have other questions after I get the engine and boiler
Thanks.
Motorcycle, mechanical, models and electronic projects.
1 of 1 stuff
https://1of1stuff.com
captain_reg
Hi Tom
Still a bit of a beginner myself. My thoughts/opinions below I'm sure others will confirm or correct.
  • I've read the same and one day would like to give it a go. But depending on the size of your gas tank you might find the gas runs out about the same time as the water does anyway.
  • Yeah, hand pumps are not unusual but so far I've always just refilled the boiler with a little funnel at the same time as the gas tank and reoiling. I've got plans for an electric pump but not required to get you started.
  • Yes you'll need to vent to allow air to fill the space left by pumping the water out. Normal practice is to have a one way check valve on the boiler in addition to the valves in the hand pump. An isolation valve also wouldn't be a bad thing incase you just want to isolate the pump from the boiler. I can imagine a big tank way up front could cause the boat to go from bow heavy to stern heavy as it empties, but that just me thinking, other might know better. You also get the situation where the boiler cools it will suck in all the water from the tank via the pump. So you would also need to fit a vacuum relief valve. Quite simple, mine fits on top of the water gauge.
Gas tanks
  • The tank will chill as the gas evaporates so lagging it would stop it being warmed as well inside the boat and would reduce the gas pressure. Best to leave as is.
  • Yes but I have seen a few that don't. I've always made my tanks removeable as much of a pain as that has been.
  • Optional but in my opnion a good one. I've got a valve designed to be turned on/off by a servo. That servo is controlled by a knob on the transmitter via a spare channel, failsafe position is off, so if signal is lost the gas shuts off. The way I've set it, it also works to throttle the gas supply.
Condensor tank
  • Optional, I never have but I think I might start. The insulation should in theory cause less of the exhaust to condense into the tank.
  • Either. With a gas boiler, good pratice is to run the pipe nearly to the top of the chimney of doing it inside.
Electronics
  • Yes. I have one with a pressure gauge, one without. Not delved into sensors yet. Wanted to try using a small camera to view the pressure & water gauge but not tried it in practice yet.
  • Never seen telemetry, just automatic boiler control.
RegardsRichard
TomF
    • 1 of 1 stuff
Thanks, Richard that is super helpful.
Tom
1 of 1 stuff
DBS88
Welcome to the dark arts of operating steam boats, it's great fun and every day is a school day. You have asked many useful and interesting relevant questions. Regarding electronics and control of gas, water and pressure, I have researched this extensively and use a variety of controls on boats. Currently the best range and the best designed controls (in my humble opinion) are made by Denes Designs. https://www.denesdesign.co.uk/home
[/size]
[/size][size=78%]Many of my findings and mistakes were published on this website in the forum in an article about installing electronic controls in a butler class tug - hope this  is helpful[/size]
  https://www.modelboatmayhem.co.uk/forum/index.php/topic,68100.0.html
1967Brutus
Gas tanks
Condensor tank
Electronics
Thanks.
You have the same boiler, burner and gastank as me, but a slightly different engine. I am not familiar with the steam requirement of your engine, so while I am 100% positive the burner and boiler can supply the engine, I do not know what consumption will actually be, because apart from your throttle hand, the engine determines steam, and thus fuel consumption.
I know this: the boiler is good up to about 3 or 3,5 bar. The burner in stock form (without possibly limiting stuff like rgulators) can handle that as well.
There is no real problem there.
In general: Small high revving props give high steam consumption, larger slower revving props (suppressed RPM) reduce steam consumption. More or less.
The boiler can hold about 350 ml of water, and until bottom of level glass, contains about 200 ml usable water (I do not recommend running below visible water level, even if some say it is not as dangerous as people think.
My M29 engine goes through this amount of water in about 15 minutes if I take it easy on the throttle. Your engine seems to be marginally larger.
The gastank however can without issues hold about 65 grammes of fuel which is good for about 60 minutes of operation.
So IMHO, a feedpump in order to extend operating time is a must (10 minutes is not very much to enjoy your boatride, no?), and 350 to 500 ml would be a good size, it would provide about half an hour of feedwater supply, plus another 10 minutes on the water stored in the boiler.
40 minutes should be a good runtime.
Buy a small scale, and weigh your empty and filled fuel tank, experiment a bit and figure out the safe fuel level.
About the water quality: Although I know some people feed their boilers from the lake, and acknowledging that most people run the plant only a few times per year which makes scale deposits etc etc not a real problem, the engineer in me refuses to recommend that option, simply because I have no idea of the water hardness in your locale.
Better to either buy demi or destilled water (Destilled has preference over demi, but both are usable) for the sole reason that at least water quality is a known and constant parameter.
I steam A LOT, so I decided to buy me a water destiller. They are very affordable from China. The VEVOR branded destiller I bought, I saw it as low as 75 Euro at some outlets, water quality is excellent, and maintenance is virtually zero if you don't run it down to its automatic stop.
I run mine at times of low electricity rates, and it is basically free because the darn thing heats my living room on its own, meaning the central heating does not have to burn any gas :D
Besides, plenty folks seem to think distilled water is healthier to drink and keeps applyances like coffeemakers in better condition, so it might be a consideration in general.
But forget that rubbish if you want, you can buy demiwater, or even destilled water usually at DIY stores for reasonable prices.
For gas: Best to use LPG (propane/butane mix at 30% propane), because Butane only works properly in warmer climates or you'll need heating on the gastank.
You do NOT want the gastank lagged or clad: It contains fuel in liquid form, but the burner needs gas. As in: "evaporated". That evaporation takes place in the tank. Evaporation NEEDS heat, and you want that heat (from ambient) to have easy access to the tank, otherwise the temperature drops and pressure with that.
Now that we are talking gastank: your tank really has a safe max filling of about 65 grammes, doe NOT overfill! That is dangerous.
Especially at a just filled tank: Make sure that the boat is static and has come to rest before opening the valve on the tank and lighting the burner.
Do NOT, repeat NOT "shake" the model when the burner is on, because you do NOT want any liquid fuel entering the gasline to the burner.
It will kill the flame with an overdose of fuel, and the evaporated fuel is heavier than air. It will remain in the boat, any attempt at relighting will cause a fireball and probably loose parts flying around.
Also, ignition is a two-handed operation: hold a burning lighter at the end of the funnel, then open the gasvalve.
NEVER first open the gasvalve to then go and get your lighter.... Same result.
A gas attenuator (boiler pressure control) is ALWAYS a good thing, it makes for a much more consistent engine run, and prevents blowing safety valves or wasting gas and water. Which type, is up to you. If you're a processcontrol nutter like me, have at it with all kinds of sensors and stuff, if not, buy an analog one like the Microcosm P5.
In general, telemetry is useless if you do not know what to do with the information, but of absolutely GREAT value if you do.
Lots of things can e alarmed in many different ways, and it totally depends on what kind of sensors are availlable for your particular set-up, I can't comment on that any more detailed.
Feedwater pumps rob engine power, so you can opt for an electric one on manual control, automated control (User "rhavrane" in the past posted quite a bit of useful info on that subject).
Personally, I linked my boiler feed to the steam throttle, works also.
Basically, you need to have SOME form of feedwatercontrol, because an empty boiler is useless, but an overfilled boiler also is spoiling a lot of fun, but a crudely adjustable pump at constant speed, approximating your particular feedwater consumption allready works pretty good for a lot of people
Feedwater preheating is not necessary, but saves between 5 and 10% fuel consumption. Talking about Alarms: IF you have a feedwater preheater, a temperature alarm will reliably warn you for a malfunctioning feedwaterpump.
The "condenser" is actually an oil separator, can best be lagged, minimizing heatloss extends operation time. Without measures, mine is full in about 15~20 minutes, and once it is full, oil will be blown out, leading to spots on the pond. Lagging it extended that to about 30 minutes, but I modified mine to automatically discharge to a dirt receptacle. the receptacle is much easier to empty than the separator (no need to cool down or depressurize anything) but most important, I value an absolute non-polluting operation. Not because I am an environmentalist (I am not) but because of clubs keeping their licenses and ponds and such. It just makes life easier if people are NOT nagging about your hobby :D
The standard displacement oiler IMHO is rubbish. It overlubricates IMHO, and does not hold much oil to begin with. I bought the one with glass body from Microcosm. Fits right in, is fairly decent in its adjustment (takes quite a bit of trial and error, but once set is fairly stable) and holds enough oil for about 3 hrs of operation. Don't get me wrong, you don't NEED that kind of operating time, but refilling is a messy job, and having a larger lubricator means you can do multiple runs without getting dirty hands, AND you can see whether you need to refill or not.
You can lubricate the rest of the engine (rods, crossheads and excenters) manually, but that is messy, and needs to be done frequently. There are zero problems with manual lubrication. However, my advise would be to make a wickfeed lubricator for that. Fill at the beginning of the day, empty it when packing up, and no mess or attention needed.
Whatever you do, whichever method you pick, the engine WILL make an oily mess. No way around that. So build your boat with that in mind. Make sure the woodwork of the floorplate under the engine is PROPERLY treated with a good PolyUrethane laquer or something like that.
If you can make a metal tray (save-all or coaming) under the engine, that is greatly advised. Oil soaked wood weakens, deteriorates and becomes unrepairable.
Personally, I pad all the free floor plating around the engine with wads of toiletpaper or kitchen tissue that I replace at the end of the day. Keeps the boat in good shape even if I do say so myself.
In general: your first installation, get to know it with everything visible and accessible, so play with it on the testbench. Make sure you're familiar with it before installing it in the boat.
Keep that visibility and accessibility in mind when building the boat around it. Sounds like "Duh!", but you wouldn't be the first finding out something important is poorly accessible or visible that he hadn't thought about beforehand, and yes, that includes me (my feedwater valve is very poorly accessible, and you need to close that valve after killing the fire, or the vacuum will draw the entire feedwatertank into the boiler...).
All in all, steaming is good fun! It requires attention and observation when starting up, when shutting down, AND DURING sailing, and personally, I like that very much. Every succesful run on the pond is an achievement of sorts.
Good luck!
TomF
    • 1 of 1 stuff
Thank you both very much, David and Brutus - there is a lot of information there for me to digest.
I did find yesterday a Microcosm mini pump P71 on eBay in the auction - no one but me bid so I got it at a very reasonable price. I hope I haven't bought a turkey !
s-l1600.jpg" border="0
I do like the idea of it running from the engine, but I would have to fit it beside the engine which aesthetically isn't ideal. So when it all arrives I may look at positioning it near the boiler and running it from an electric motor ( I may try an hide/disguise the motor). The electric motor could then be used to adjust the water flow.
Love to have comments
Thanks again
Tom
1 of 1 stuff
rhavrane
  • Steam passionate collector
Bonjour Tom,
I also have bought this little pump : https://youtu.be/vSo2UE4Ug9s
Checked with Jin, please note that this pump is not designed to manage the re-supply of a pressure boiler.
I also have several Microcosm steam machines and boilers, including the ones shown or your pictures, the flywheel is not a marine one.
And would kindly suggest uou to bid on eBay the P5 gas regulator ofter cheaper there than on Jin's siten example  : https://youtu.be/2dFmxZs5vOQ
Furthermore, for safety reasons, I equip my boats as soon as I can with a radio-controlled gas cut-off valve
Raphaël
SailorGreg
I am by no means an expert, but learnt a huge amount from a standing start a few years back when I did a steam launch.  For what it's worth, my views are below -
  • I have read some conflicting information about the use of tap water (scaling the boiler for example) but what about pond water after all there is plenty of it when running the boat! If it looks clean can it be used, perhaps running it through a paper filter first?  If you have a condensing tumble drier, save the water from that.  It might not be 100% pure but it's way better than tap water.  You can use pond water if it's clean-ish. And if you are only going to run your launch infrequently, it will take a very long time for tap water to scale up the boiler.
  • I can see the advantage of a separate water tank versus filling the boiler directly, but can the boiler be topped up while it is still hot, then what about the pressure inside the boiler would a hand pump overcome the pressure or would an automatic/electric pump be better?  Yes, a pump (electric or engine-driven) can top up the boiler while running  It feeds the water through a valve in the side of the boiler which stops steam pressure coming back into the pump.  It will also incorporate a by-pass valve so you can adjust the rate at which water is fed to the boiler, the surplus being returned to the tank. But of course the pump operates at a higher pressure than the boiler or it couldn't push water in to the boiler.
  • I have seen water tanks being formed in the bow of the boat, which seems like a good use of space. Do the tanks need venting to let air in? Do you need to fit a stop cock between a hand pump and boiler or are the hand pumps good enough to withstand boiler pressure?  Yes, you need a vent pipe or you will quickly generate a vacuum in the water tank.  No stop cock is needed.
Gas tanks
  • Can gas tanks be lagged (for cosmetic reasons) like the boiler or is it best to leave it as is?  Best to leave as is so the tank can stay at room temperature as the liquid evaporates - otherwise it will cool quickly and reduce the flow of gas.
  • Is it advisable/sensible that gas tanks should be filled outside the boat?  Yes.
  • Should a gas regulator/cutoff be fitted in case you need to turn off the boiler remotely - if so what are the options?  Up to you, remote valves are available, but many steam plants are operated quite safely without them.
Condensor tank
  • Same question as the gas tank - is it OK to lag?  Again, you want some thermal interchange with the environment, so probably best left bare.
  • Can I exit the steam into the boiler chimney, or is it best to leave a pipe running up the side of the chimney?  Good practice is a separate pipe external to the chimney as you don't want condensing steam inside the base of your chimney.
Electronics
  • I see it is possible to fit pressure sensors, water level sensors, ECU, GCU etc - would any or all of these be useful/desirable?  Up to you, but as this is your first steam plant, I would tend to keep it simple.  Extras can be added later if you wish.
  • Are there any telemetry options that could signal any potential issues to the transmitter?  Again, suggest you stick to a simple set up to begin with.
Thanks.
1967Brutus
I agree with basically everything in this post (I think it is better to lag the condenser, but the difference is not all that shocking, so alas), but:
The water from a tumble dryer is very clear, but I would NOT use it, because it is of horrible chemical quality, containing lint and being acidic.
If you don't believe me: try taste a sip... I am sure you don't want to drink it, and boilers are WAY more picky on water than humans... :D
The same is the case for condensate taken from AirConditioning systems. I have seen full blown steamsystems on the tankers I worked on, turn to horrible malfunctioning scrapheaps, literally. The problems in model steam will not be nearly as catastrophic, but still, I would stay away from that.
Bought water (demi or distilled) is not that expensive and far, far better. Heck, rainwater usually is even better.
Just to be clear: ALL water will make model steam engines work. No ifs and buts. Immediately followed by the first but: the problems only arise over time, but they WILL arise. Some problems will even arise virtually immediately.
The kind of water used determines how to handle the boiler.
-Tapwater will require a VERY often descaling, will in general perform poor and engine wear will increase, especially in "brass engines".
-Rainwater, condensate from tumbledryers or airconditionings contain lint and is acidic (rainwater only slightly, but AC drainage can be VERY acidic). Copper can handle the acidity better than Brass, but you both don't know the exact composition of the water, nor the alloy the boiler is made of...
It CAN cause deposits other than lime, especially water from tumble driers.
-Demiwater will over the course of MANY years cause dezincification of the brass. Copper boilers are not really affected, Brass boilers can be, depending on the alloy used, but since you don't know that alloy...
Boilers will otherwise remain reasonably clean internally.
-Desitlled water is safest option, basically being chemically neutral.
Take your pick, and act accordingly.
Anyone interested in more detailed info, happy to provide, but I think that is outside the scope of this thread.
1967Brutus
Thanks again
Tom
It is a beautiful pump, but I am not sure if it is intended for (or suitable for) use as feedpump.
There is indeed a LOT of info, and it needs digesting. Don't worry about that. That digesting will happen over time, and will go along with the process of "building experience". NO ONE of us, got it exactly right the first time, and the entire learning process with all its ups and downs can be extremely satisfying.
I was lucky that my learning process (including many times falling flat on my face) was on real life huge installations owned by someone else and I got paid for falling flat on my face. Especially the "getting paid" thing was good... :D
Just me having a "philosofical moment": If you treat it as an "educational toy" instead of "just a toy", you'll have much more fun because the things that went wrong and finding the solutions for those issues will beccome part of the fun and challenge, instead of being mere "dissapointing malfunctions".
It is your first steampowered boat. Focus on its visual appearance as much as you like, but keep the functioning of the installation as a priority. Don't compromise function for visuals. Do that with your 2nd boat, which if you pick up my train of thought, undoubtedly WILL come along.
Steam power is fascinating if you do it right.
rhavrane
Bonjour,
I confirm, I also have one and asked Jin if I coould use it to feed a boiler, I has confirmed that this pump is NOT suitable to work under a pressure :
Raphaël
1967Brutus
Bonjour,
IMHO, there is very little in the construction that would make it unsuitable, other than the transmission ratio.
The pump itself, constructionwise I see nothing that would limit its delivery pressure. It seems to be a normal crankdriven positive displacement pump.
The valves used internally, I am 100% sure are the exact same items as used in Jin's feedwaterpump. I suspect the plunger seal O-rings also are identical to what is used in Jin's boiler feedpump.
The biggest issue for use as a feedwaterpump, I think, will be in creating the proper gearing ratio between engine crankshaft and pump drive.
That issue would immediately go away with even the tiniest of geared electric motors and a simple, cheap and costeffective ESC.
The aircushion (shock absorber) can be left in place, it simply won't have any function at the RPM required to feed a boiler.
For a general impression: the boiler Tom is using will require a max feedrate, for normal operation, of maybe 15 or 20 ml per minute (mine tops out at about 12 or 13).
I do not know the plunger diameter and stroke, but if known, the required pump RPM should be very easy to calculate, but I would estimate it to be below 60 RPM on the crank.
rhavrane
Bonjour,
Tom, as you know Microcosm, I would kindly suggest you to install his pump but change its 70 RPM engine by a 280 RPM one compatible with the pump and found on eBay : https://youtu.be/j0yn0yaT5F0
Besides this, the issue with this boiler (I have 3 of them) is that there is no ferrule to install a check valve.
I have asked Jin to build me a custom water level base to feed one on my Wacht Am Rhein tug https://youtu.be/qthtgp7T9aQ but did not succeed when I asked him another one  (I don't know how to share a picture, here is its link) :
https://www.modelboatmayhemimages.co.uk/image/tdnnX
Raphaël
1967Brutus
I think it won't be hard to install any commercially availlable inline checkvalve in the feedline?
This one comes to mind: Speisekopf | REGNER (regner-dampftechnik.com)
rhavrane
Bonjour,
The issue is not to find the valve, but where to install it.
You can't put it on the steam line because the water would directly go to the machine, on the top, the water will also go to it and so there is no other entry pont in the boiler than the water level (that I also use for my gas regulators).
Raphaël
1967Brutus
If anyone WANTS to install one, it absolutely is not hard to simply install it in the feedwaterline? With a bit of handywork, a thread-adapter between Regner standard and Microcosm standard can reasonably easily be made, and if not, the coupling of the Microcosm is allready there. A short piece of 3 mm tubing brazed in, and a coupler from Regner
(this part: https://www.regner-dampftechnik.com/product-page/schneidring combined with this part: https://www.regner-dampftechnik.com/product-page/%C3%BCberwurfmuttern-sw-6-m5-x-0-5-f%C3%BCr-%C3%B8-3mm-10-st%C3%BCck) connects the non return valve to the feedwaterinlet
The NR valve does not have to bolt directly to the boiler. It is preferrable, but not necessary.
Personally, I am allready running my boiler for about 70 hours without a separate NR valve. Keep in mind, that this NR valve, in life size installations, is NOT there for the safety of the boiler itself, but for the safety of operating personel. That issue is completely absent for model steam installations and operating the system with a feedwater checkvalve is exactly as safe or dangerous as without.
As for the pressure tap for the regulator: There IS an unused connection on the steamdome. I used that one for the pressure tap to the regulator.
A loop in the line, same like for the pressure gauge, keeps the regulator (in my case an electronic sensor) safe.
TomF
    • 1 of 1 stuff
Thank you again for the very useful information.
I had a reply from Jin and he said - "this is the pump that pumps water for crops" !.
Apart from using it as a bilge pump, any other ideas if it could be put to sensible use on a boat?
I will buy a Microcosm M11 Electric pump.
Tom
1 of 1 stuff
1967Brutus
A bilge pump in a steamboat is a very bad idea unless you want to also build an Oily Water Separator: Steamboats, IF they have water in the bilges, WILL also have oil there, pumping that out will result in unfriendly facs in your club...
But depending on its pumping capacity, you COULD use it to supply a condenser with outboard cooling water... (I know... I am the kind of idiot that would do such a thing... But it IS a thought...).
I will buy a Microcosm M11 Electric pump.Tom
Good plan! I think it will be a better pump than the Regner that I have, especially WRT capacity (the stock Regner can nowhre near keep up with your boilers needs).
rhavrane
Bonjour Tom,
By default, the M11 pump is coupled with a 70 RPM electric motor, quite to slow : https://youtu.be/uW7OW941xG0
so I bought a 280 RPM motor : https://youtu.be/FNy_x-RR9mE
And the result is validated : https://youtu.be/j0yn0yaT5F0
Raphaël
TomF
    • 1 of 1 stuff
Thank you all again for your suggestions. I think on the subject of water feed pumps and controls I'm going to experiment with this old water level control design I found in this post -
https://www.modelboatmayhem.co.uk/forum/index.php/topic,69411.msg755999.html#msg755999
detail are here.
https://stalbansmes.com/wp-content/uploads/2020/11/Water-Level-Control-.pdf
I know there are commercial ones available, but I have a reasonable grasp of electronics so cI an adapt it to my needs.
If anyone has made one I'd love to hear from you.
Tom
1 of 1 stuff
1967Brutus
detail are here.
Tom
You realize, that this set-up works on conductivity of the boiler water, right? That is in contradiction with that the water used ideally should have zro conductivity, and conductivity rises over time due to concentration of TDS value...
I would stay away from that. Those sets can work, but personally, IF I had to use an active boiler level control, I would go for one of the set-ups that make use of an optical detector on the level glass... This type of leveldetection is independent of waterquality.
My thoughts are that you can still use the same base electronics (a unit controlling a pump based on a on/off signal), just that imput suitable to be ativated by the internal probe measuring resistance should be adapted to one that can work with the on/off signal of an optical sensor.
That's just my 2 cents...
1967Brutus
Tom
And then I see this... A Microcosm M71 pump being used as a feedwaterpump... And having no issues...
https://www.youtube.com/watch?v=fRW5iWENbN8
rhavrane
Bonjour,
Sorry to insist, the P71 pump is not suitable for a boiler that works under pressure (30 - 50 PSI).
The Wimlesco shown on the video is a toy working at +/- 10 -15 PSI and without any check valve... Make your own experience then but I wanted to inform you in advance  :-))
Raphaël
1967Brutus
Bonjour,
Oh, it is not my pump, and not my boiler, NOR my advise to use it. That video just happened to pop up in my daily YT feed all of a sudden, and I thought that funny because we just discussed that the other day, is all...
But to be honest: I am an engineer by trade. I need a bit more than just "Jin says so" before I would discard that pump as unusable. The construction of that pump can easily handle up to 5 bar (75 psi). That pressure will only cause a force on the rods of less than 10N...
TomF
    • 1 of 1 stuff
About sight glass level detectors, can they be made of plastic or are they only ever glass?
Tom
1 of 1 stuff
Page created in 1.043 seconds with 17 queries.
