Author Topic: Fleetscale Type 45 build  (Read 7886 times)
6705russell
« on: August 04, 2024, 07:48:44 pm »
Evening all
After a 7 hour round trip I have bought myself a part built Fleetscale Type 45 destroyer, previous owner had decided it was to big to handle so chopped in half, bulkheads at the ends and the two halves have 1/2 inch stainless rods to marry up and a clamp to secure in the hull, never really thought of doing it this way but am in two minds whether to leave as is or bolt the two together, fill and have as one hull, my only worry is when it is joined there is a gap where the hull joins, have others done it this way?
6705russell
Re: Fleetscale Type 45 build
« Reply #1 on: August 04, 2024, 07:57:03 pm »
Quick picture of what I’m dealing with..
« Reply #2 on: August 04, 2024, 07:59:41 pm »
The joint will eventually wear and then flex but it depends on the fit.
6705russell
« Reply #3 on: August 04, 2024, 08:02:34 pm »
Thanks Bob,
I thought that to be fair, I was thinking four 10mm bolts and bolt together thinking it wouldn’t move but like you say it may, my other option would be to fettle and sand the two bulkheads so they married almost perfectly, tough job but possible I suppose?
« Reply #4 on: August 04, 2024, 08:10:03 pm »
Do you need to split the hull for transport, the most wear is then launching and recovering as that is when the joint suffers most stress.
6705russell
« Reply #5 on: August 04, 2024, 08:14:56 pm »
At just over 2mtr length  it would be ideal if kept has two halves I suppose, didn’t want the joint look a dogs dinner though, plus all paint has got to be stripped and would be easier to work on.
« Reply #6 on: August 04, 2024, 08:18:31 pm »
It might reduce the stresses if you can build her up in the water then fit batteries and ballast.
madrob
« Reply #7 on: August 05, 2024, 01:06:48 am »
Frogman3 on this forum has built a HMS tiger with a hull joint,  theres a thread in the warships section on this forum
hes built a few more ships with hull joins and having seen them at shows the joint is barely noticeable
6705russell
« Reply #8 on: August 05, 2024, 04:30:58 pm »
Appreciate that, will have a search..
6705russell
« Reply #9 on: August 21, 2024, 08:00:36 pm »
I have decided to keep the Type 45 as two halves for ease of stirring and transporting, all has been stripped down back to fibre glass and I have started to etch prime, previous owner who started the build had not used primer so didn’t take to long to strip back. New decks have been made and in the process of fitting, filling and sanding.
frogman3
« Reply #10 on: August 22, 2024, 06:59:41 am »
HI there yes ive built a few ship with a hull jiont an they look fairly reasnonable an i just fitted 4 bolts glued in the front section an then the bolts slide through brass sleves to stop wear an then just tightin both hulls togeather by butterfly nuts an its a fairly easy way an the bolt holes are all above the W/L AN ELETRICS are computer plug also fitted into the hull to carry power to the rearhull section an yes lookin at how the other gent treid to jion up the hull is wow why the big holes below the W/L an did it leak when in the water as to me i cant see how this idea worked but i hope you can get a better idea of jioning the hull an you are quite welcome to copy my idea if you want if it helps you sir
ATB
Chrisb builder of hms tiger C20  :-))
6705russell
« Reply #11 on: August 24, 2024, 08:36:19 pm »
Thanks Chris
The holes you see are the ends of heavy gauge aluminum tubes set inside the hull, these have end caps glued on so no water passes into the hull, there are three aluminum rods that slide into one half and the other half of the hull slides onto these, once together there is a large lever clamp inside the hull that pulls the two tight, watertight.
Couple of pics from today, new rad mounts made and some filling and sanding done to the main tower before a coat of paint..
frogman3
« Reply #12 on: August 24, 2024, 10:35:21 pm »
HI WELL from what i can see it looks like you now have a decent hull jiont so happy sailin when she is done
chrisb :-))
6705russell
« Reply #13 on: August 26, 2024, 05:58:50 pm »
Now that there is some paint going on the joint is less noticeable side on..
frogman3
« Reply #14 on: August 30, 2024, 08:56:19 pm »
HI YES your hull jiont looks a lot better now an well painted on the hull
chrisb :-))
6705russell
« Reply #15 on: September 01, 2024, 02:52:18 pm »
Made the internal hanger walls/deck, 2nd Lynx heli will be stored in here. Will add some lighting in there at some point, the walls and deck are all removable as the shaft oilers are underneath.
T888
« Reply #16 on: September 02, 2024, 02:20:12 am »
This may help you with internal detailing
https://dmc_rulez.artstation.com/projects/g2JXrx
Regards David
6705russell
« Reply #17 on: September 02, 2024, 07:45:04 pm »
Excellent pictures thanks, wasn’t going go to town inside the hanger but now I have seen them I will certainly add some more detail now.
6705russell
« Reply #18 on: September 05, 2024, 07:38:05 pm »
I will change the title of this thread as I will probably post updates as I progress the build, couple more pics as I have to take outside to turn the ship round and take back in the workshop, have to work on one side at a time..
6705russell
« Reply #19 on: September 22, 2024, 05:01:26 pm »
Far to wet and damp today in the garage so knocked up a 72 scale Merlin, will make two as one will be blades folded for in the hanger, eyes not what they used to be so had to leave some decals off..
6705russell
« Reply #20 on: November 17, 2024, 06:06:18 pm »
Number 2 Merlin to sit inside the hanger.
6705russell
« Reply #21 on: December 25, 2024, 05:03:34 pm »
A little more done on the 72 today, for some reason the rear deck had popped up, the epoxy didn’t hold it so had to remove and refit.
philk
« Reply #22 on: December 27, 2024, 04:40:33 pm »
Love those Merlin's really want one for my t45 but can't find one in the right scale only a lynx
6705russell
« Reply #23 on: December 27, 2024, 04:49:31 pm »
What scale are you after?
SimonCornes
  • Member of Potteries Model Boat Club
« Reply #24 on: December 28, 2024, 12:02:25 pm »
Are you sure those bilge keels are right? They look very big to me. Might be an idea to find some photos of T45's in dry dock to check. A lot easier to take some off now than when finished I'd say. Otherwise it's a very impressive build! Have you thought of screwing that flightdeck down? I assume the inside of the hull has strip wood around the edges? Screw then fill then paint!
All the best
Page created in 0.324 seconds with 17 queries.
