hi all
Ive been asked several times how do I get the shape of the hull for the stand. Obviously there are several ways of doing this, its pretty easy if you have the sectional drawings of the hull from the plans.
In which case, you select the desired frames (section) and trace these out to produce the profile for the stand.
Sometimes we dont have that though, and, what I have done on one occasion is made a small guage up out of scraps of plywood. I have included a quick scribble to show. You will see the guage is basically like a 'hangman's jib' :-\
The top jib is divided into equally spaced segments and I normally use 10mm spacings or 1/2 inch spacings.
The procedure which I used was - I turned the hull upside down, supported it so that the keel was vertical so the keel would not move or rock. Marked on the hull approximately where I wanted the stand to be and then slid the jig in and adjusted the height of the top arm so it rested onto the keel and was at right angles to the keel.
With a 6 inch ruler, held at right angles to the top of jig, I moved the ruler down until it touched the hull as in Drawing A. I took note of the measurement from the top of the jig.
I plotted these off on a graph on a piece of paper with the same equal spacings as the jig. Once I had sufficient markings on the graph, I joined the dotted lines up to form the profile of the hull and then I took a tracing transferred that to the plywood, remembering to flip the tracing paper over to make two sides of the profile and that gave me the shape of the profile I required for my stand.
Hope this is of some help.
aye
john e
bluebird
