Derek,
Thank you for a kind and professional comment on heat transfer of the water -cooling coils I made.
Yes, indeed , what you have mentioned is surely true and reasonable for an effective cooling of the motor cans, as well as
is ideal and better to do. However, as you know a brass (tube) itself is also so good a material to conduct the heat and I made
the coils to get them to touch as much surface of the motor cans as possible to contact the water inside the coil tubes.
Even this level of craftmanship will I suppose do a good job from my experience of brushed motor boats in the past.
This style of cooling is not the best, but necessary and sufficient style for this PT-109(JP).
I have learned a new knowledge that you suggested to use thermally conductive paste.
I will keep it in mind
The pick of steel tank (98 pounds) is equipped with a cooling water coils and a radiator to run in the summer.
All the drive system is fully covered with steel which becomes toooo hot in mid-summer. Only forced water cooling system
could save this tank in summer run. Just an appendix!!!!
Thanks Derek.
