Author Topic: R9 900mHz module / Taranus 2019XD for sub?  (Read 14547 times)
Tim Logan
  • Lifeboats & Tugs
« on: November 22, 2024, 09:56:40 pm »
Is there any reason a Taranus 2019XD with the R9 900mHz module would NOT make a good submarine radio? I am aware of the depth limitation being in the 4 to 6 foot range. That is not an issue to me.
   My understanding is that the sub would be running constantly on 900 MHz whether submerged or on the surface because switching between frequencies is done manually at the transmitter. (ie not redundant). For this reason I’m wondering if there’s any limitation to using 900 MHz on the surface? The only other limitation I can think of would be the battery power which would depend on how many mW you’re sending out at 900mHz. The module itself does have the ability to have an external battery hooked up.
[/size]i’m trying to decide if the R9 will suffice or if I need to bite the bullet and go for the FrSky X18 tandem. Thank you in advance for any input.[/color]
Umi_Ryuzuki
    • Models and Miniatures
Re: R9 900mHz module / Taranus 2019XD for sub?
« Reply #1 on: November 23, 2024, 05:34:23 am »
I don't think its a good idea to use 900mhz.
For surface running no issues, but as soon as you submerge any distance away from the model, you may lose signal.
https://www.youtube.com/watch?v=hGDxRDqIfdk
rhavrane
  • Steam passionate collector
« Reply #2 on: November 23, 2024, 09:32:24 am »
Bonjour Tim,
I agree with Umi_Ryuzuki, I have had the opportunity to meet several model submariners (see my videos) and the "best / less bad" frequency which should be used is 27 MHZ then 41 MHZ. Above, no transmission underwater.
Example : https://youtu.be/MyWzYXgae_c
Raphaël
Tim Logan
  • Lifeboats & Tugs
« Reply #3 on: November 23, 2024, 12:06:51 pm »
Umi and Raphael - thank you. The use of 900mHz in tandem with 2.4 has been tested quite a bit in the US sub community and accepted. Normal operating distance (with 2.4) and submerged 4 - 6’ (with 900) works just fine. Most sub drivers are totally happy with that as it is rather fool hardy to seek greater depths. So that part I am not worried about. What I don’t know is if 900 (without a tandem freq) on the surface has any limitations.
  The ideal of  course (both cost wise and operationally) would be 75mHz. However, finding good clean 75mHz systems is like pulling hen’s teeth - just very difficult to find. If I could find one, that would be my choice. If you know of a source in the US, that would be great!!! Thanks again.
JimG
« Reply #4 on: November 23, 2024, 01:37:23 pm »
There should be no problem using the 900MHz module for both surface and submerged. 900 MHz will have a longer range than the 2.4 GHz for the same transmitted power and is less affected by water absorption. Many long distance fliers use the 900 MHz band for their planes due to the much longer range. (Ignoring the legality or not of flying out of sight)
Jim
Dundee Model Boat club
Tim Logan
  • Lifeboats & Tugs
« Reply #5 on: November 23, 2024, 09:32:18 pm »
Jim
Thanks Jim - that’s what I needed  :-))
tsenecal
« Reply #6 on: November 23, 2024, 10:24:39 pm »
I have been using 900mhz for ALL my subs since about 2017
I currently use ExpressLRS modules for most, but i have tested:
Frsky ACCST r9
Frsky ACCESS r9
ExpressLRS 900mhz
TBS Crossfire 900mhz
OpenLRSng 900mhz
Futaba TM-18 900mhz
I have even "successfully" forced Jeti 900mhz backup to work.
All have worked reasonably well.
for more info on this topic:
https://www.theassociationofmodelsubmariners.com/t1842-868-915-mhz-as-a-viable-frequency-for-submarines
Regarding OPs original question regarding the 2019 ACCESS taranis x9d with an r9 receiver, I specifically tested the Frsky Qx7, with the 2019 ACCESS R9 module, with the Frsky ACCESS R9 SX six channel receiver.  My x9d is the older ACCST model, but the 2019 Qx7 and x9d are identical in functionality when using the 2019 ACCESS R9 module.
One of the nice features of all the Frsky radios is that all the ACCESS models support the independent use of R9, including the Tandem models with their internal 900mhz rf deck.  I also have a Frsky x20 Tandem, and it will work with the same r9 sx receiver with out needing an external 900mhz module.
Tim Logan
  • Lifeboats & Tugs
« Reply #7 on: November 23, 2024, 10:40:45 pm »
Tsenecal -
  That’s great feedback. Thank you. What output wattage  are using with 900mHz? My understanding is that you need to up the wattage output if your submersing up to 4’ or so. And if so, have you had to supplement your radio’s battery? Thank you again!!
Subsonuc Mike
« Reply #8 on: February 13, 2025, 10:14:18 pm »
Hello, I'll throw my hat in too.
I've been trying out 868mhz in subs. I set my radios power to dynamic, automatically changing the power between 100mW and 500mW.
Running the sub with the antenna about 8" below the surface the power sat happy at 100mW jumping up to 500mW for a couple of seconds once.
There isn't a need for an external battery this way with my transmitter unless you get in to the 1-2W range.
rhavrane
« Reply #9 on: July 12, 2025, 07:28:25 am »
Bonjour,
Thanks to these messages, I understand that regulation on transmitter power depends on each country. In France, we are limited to 10 mW!
Raphaël
Subculture
    • Dive-in to Model submarines
« Reply #10 on: July 12, 2025, 02:21:04 pm »
How many people stick to that limit, I wonder?
rhavrane
« Reply #11 on: July 12, 2025, 02:38:11 pm »
Bonjour,
99.99% of users I meet because they are primarily modelers and not electronics engineers, therefore unable to manufacture amplifiers because they are not for sale.
10 mW 27 MHz or 35 MHz transmitters allow 4/5 meters dives  :-))
Raphaël
Subculture
« Reply #12 on: July 12, 2025, 02:57:01 pm »
With these modern systems the power output can be adjusted easily in the transmitter.
tsenecal
« Reply #13 on: July 12, 2025, 05:03:48 pm »
I have my 915mhz systems set for dynamic 250mw with no problems... "no reason to boil the water."
Years ago, i spent time testing 433mhz OpenLRSng equipment for a modeler in Belgium.  He also was limited to 10mw, and with the 433mhz (458mhz where he lived) my testing showed depths of 5 feet were able to be reached at that power output without issue.  Sadly i don't know of any commercial products made in the 433/458 frequencies anymore.   I see an occasional ExpressLRS system pop up in that frequency on aliexpress, but it is not something that is formally covered by the ExpressLRS community, and you are basically on your own for support.
Subculture
« Reply #14 on: July 15, 2025, 02:03:48 pm »
The persistent shift in standards on these systems is a pain in the backside. With the old low frequency equipment there was largely a standard in place for decades, but now manufacturers seem to come and go often leaving owners with obsolete systems.
Pat-K
« Reply #15 on: August 26, 2025, 10:18:54 am »
FrSky Transmitters are dual frequency both 2.4Hmz and 900 and they are a nice bit of kit with up to 24 channels
Akira
« Reply #16 on: November 23, 2025, 10:20:35 pm »
In the US I believe, but don't quote me on this, that 900mhz can be broadcast at 1 Watt.
dodgy geezer
« Reply #17 on: November 24, 2025, 10:12:36 pm »
I wonder whether a directional aerial would help concentrate the power where it is needed - as well as avoiding sending it where it is not...
A submarine ought to be fairly simple to track...
