Author Topic: Bluebird of Chelsea - build notes - after jpdenver  (Read 4495 times)
David220747
« on: January 14, 2025, 03:44:44 am »
Notes of my build using the guidance of "Bluebird of Chelsea - my winter build
David220747
Re: Bluebird of Chelsea - build notes - after jpdenver
« Reply #1 on: January 14, 2025, 04:11:12 am »
I have started building the 1:18 scale Bluebird of Chelsea, making heavy use of Jim Denver's posts. I cannot achieve such a detailed description, but instead will seek to add some footnotes to it. I have finished the keel and hull framework.  Although at times difficult to understand I am impressed by the manual - it is quite detailed and compares very favourably with the perfunctory manuals that came with two of my previous Dumas kits (the USS Crockett and the Dauntless), where again I drew heavily on good online forums and liked the resulting models very much.  The hull positioning plate on which the framework is built is very helpful.  Note that the piece "L13" should be positioned within the ribs before they are glued down.  To bevel the ribs, I used a spindle sander.  The 6x6mm paulownia "dragon ribs" would not easily bend to match the tight curve at the bow, so I used a steam wallpaper stripper to soften the wood and then bend it to shape.
« Reply #2 on: January 14, 2025, 06:15:49 am »
G'day David...& welcome to MBM
Reading Jim Denvers previous work will assist greatly! O0
Keep us posted with images as the build progresses  <*<
David220747
« Reply #3 on: February 01, 2025, 07:32:31 am »
Photos of current planking progress.  So far all has been done with full length planks, bow to stern.  To complete it the planks now have to be cut to match the variable gaps, trickier!
David220747
« Reply #4 on: February 02, 2025, 11:42:18 pm »
Initial planking complete.  Main tools used are shown: clamps, spring clips, modellers' pins, weights and aliphatic resin.
jpdenver
  • Just an old fart.
« Reply #5 on: February 22, 2025, 01:18:17 am »
JP Denver here -  I can only say how pleased I am that my work is appreciated.  It has been a while since I was active here and
I have been working on some larger land-based steam projects.
I would be glad to answer any questions you may have.  I will say that I took a bit of "artistic license" on some of the
details on my build.    So I look forward to watching your builds.
Regards to all.Jim Pope(JPDENVER)Denver, Colorado USA
Son of a Son of a Sailor.
David220747
« Reply #6 on: February 22, 2025, 04:17:41 am »
Hi Jim
Thanks for the reply.  Stlll moving on.  Have sealed the inside and now face sanding, filling and glassing. The instructions suggest that the deck should be temporarily attached so that the whole thing can be sanded true, but this is intimidating.  I will look at the practicalities during the week.  Any advice?
jpdenver
  • Just an old fart.
« Reply #7 on: February 22, 2025, 05:34:36 am »
David,
If I remember, I fitted the deck temporarily just to make sure it lined up.  Then I removed it.
Then I planked it. I think you can see that I did not use the method of "caulking" they proposed which was to gluepieces vertically and then sand them down.
I bought the styrene caulk pieces and used those.  That caused the planking to be a bit wider, so then I cut the outside edges down to fit.
I also used a liberal amount of 1/16 x 1/16 inch mahogany as gunnels and trim all over the place.
I waited to cut in the portholes and also chose not to use the ones provided I got more substantial metal pieces and fiddly bitsfrom RBModels.
In general I used a lot of brass trim from my own stock.  1/16" and 1/8" angle pieces.
Also note that the original Bluebird only had one rudder.
Oh, and the motors provided with the kit were pretty bad, I replaced those.
On the hull, I smeared wood filler all over it on the outside and then sanded and sanded and sanded.
When I was done I epoxied it, inside too.
Yours looks great so far.
Jim
jpdenver
  • Just an old fart.
« Reply #8 on: February 22, 2025, 05:39:30 am »
Another thought -
If you are going to light up the bow cabin, make sure you place the wires and lamps before youseal up the deck.  I also packed the bow with foam for buoyancy. I put white parchment behind the
portholes so you did not see the raw guts when the lights were on.
Later,Jim
David220747
« Reply #9 on: February 22, 2025, 06:40:34 am »
Thanks Jim, it is over 35 degrees here this weekend, the opposite of your description, so I will not be doing much, except think through this step fairly carefully.  Like you I have rejected the accompanying motors and bought two MFA 385 low noise motors which I hope will work out ok. I think I will stick with two rudders although I am a bit dismayed about how they came in the kit, requiring the blades to be soldered to the shafts.
On the filler, I am currently planning to use car body filler which I have used on other boats but will make a final decision once I have worked out how much is needed after sanding.
I quite like the appearance/shape of the hull.
A long way to go ...............
David
David220747
« Reply #10 on: April 25, 2025, 12:09:39 am »
Further limited progress.
I planned like Jim to buy a tender rather than construct it, but my favoured source, the marketplace on Shapeways, has gone, so I have built it from the kit. It is small and the structure is delicate causing lots of difficulties for older, bigger hands. The result is, shall we say, average so later I make look for a more presentable option.
I have pretty much completed sanding the hull, with one more careful check needed to make sure that all roughness has been ironed out.  According to the plan, I should now slash through the hull to make spaces for the two stabilizers ("anti-sway fins"). But I would hate to do that and looking over the hull and keel I am convinced it will be stable without these additions.  So, like Jim, I will exercise some licence and leave them out.  I hope this does not prove to be a mistake.
So next will be the fiberglass.
I have had some difficulties with the kit. I agree with Jim's overview that what is supplied is of really good quality and the whole thing is very impressive in its detail, although of course this does make quite high demands on the builder. The kit I received seemed to omit some bits and in communication with the sender I have received some replacements.  But I have also chosen to buy other materials locally (there is a superb model boat shop nearby called Float a Boat, don't know what I would do without it).  It is actually quite difficult to check whether the kit is complete when it is opened.  There is so much to check, and the really very comprehensive instructions and list of parts are not all that easy to understand - for example, the instructions cover both scales of kit and some parts have been re-engineered from the original version.
Hellboy Paul
« Reply #11 on: April 26, 2025, 10:45:55 am »
How about this for the tender.
https://www.ebay.co.uk/itm/285397219612
Paul..
David220747
« Reply #12 on: April 27, 2025, 04:44:41 am »
Thanks Paul.  Looks the part and is a lot cheaper than a local purchase.
David
David220747
« Reply #13 on: June 23, 2025, 09:08:51 am »
I have finally glassed the hull using 3 or 4 coats of Z-poxy finishing resin. Next is final sanding and then using a primer/filler and yet more sanding to prepare it for painting.  It is a bit too cold to attempt priming so will probably wait until the Spring.
In the meantime, I have been working on the furniture.  Very demanding.  Locating the pieces is challenging.  They are not numbered on the wood sheets and identifying them from the instructions is also difficult because the pictures of the sheets are not an exact match. Sorting through the hundreds of pieces is very much like doing a jigsaw.  It is made doubly difficult by the fragility of the very thin wooden sheets.
The etched metal parts are amazing, but some are far too tiny for me to work with, so I took short-cuts! In particular, I have not included the brass studs around some of the furniture but have ordered some very thin brass nails which should be easier to install. I also could not find the gimballed plastic compass, so made a substitute out of wood.
The skylight is a good example of the difficulties. All the wood is very fragile so gluing it together has to be done carefully, or it will break into small pieces. In printing off the instruction manual, I had put a couple of pages in the wrong order and missed the etched rectangles covering the top of the skylight so, of course, the various cut-outs did not match the wood frame which I had made!  But I did finally make it fit.
So making these small pieces of furniture takes quite a time but, on the other hand, the result is quite pleasing - the varnished wood coming up very well.
The next blocks of work are:
- continuing with the furniture and superstructure, during our winter
- finishing the hull
- preparing the mechanics: prop shafts, motors and rudders, which requires soldering the rudders to the rudder shafts and soldering the prop shaft supports which are attached under the hull at the stern; not looking forward to this!
Page created in 0.179 seconds with 18 queries.
