Author Topic: Dave Milbourn's Huntsman  (Read 20803 times)
ChrisF
  • What's my favourite cake!
Re: Dave Milbourn's Huntsman
« Reply #25 on: January 30, 2025, 06:37:53 pm »
Certainly sounds like it as the ESC and the motor are the only things left in the equation.
You don't have another one you can try?
KitS
« Reply #26 on: January 30, 2025, 09:13:08 pm »
No, this is the first boat I've ever had with a brushless motor and ESC so it's all new stuff to me.
Kit
ChrisF
« Reply #27 on: January 30, 2025, 09:26:56 pm »
Never thought of that. They're great when they work as they should. You'll get to the bottom of it.
Chris
« Reply #28 on: January 31, 2025, 10:26:27 am »
Wonder, if with Dave's expertise and knowledge of the elecrtonickery, he only intended it to go forwards?
 Regards  Ian
 Know any good Mediums?
« Reply #29 on: January 31, 2025, 03:04:41 pm »
No, the ESC was recommended for the SLEC kit version and mention that the ESC is forward & reverse,
Just had a rummage in my workshop and actually found the program card but I never needed to use it as the defaults (including F/R) were OK. My radio for the model was a cheap Saturn 4ch set from Howes. It worked out of the box as i recall.
My later Swordsman kit has the same ESC and the radio is Specktrum TX and a generic 'Lemon' RX. Again no problems.
I use left stick for throttle and right stick for rudder.
It does suggest there may be something amiss with the ESC.
ps: Have you used the programming card to set everything back to the defaults? (black boxes on the instructions)?
« Reply #30 on: February 01, 2025, 09:18:12 am »
Sorry, I didn't realize we were discussing recommendations, I though Daves boat came with the ESC and motor already installed :embarrassed:
« Reply #31 on: February 01, 2025, 10:35:14 am »
It did come with the ESC Ian, KitS is having problems getting it to work.
I had the same ESC in both my Faireys which worked fine.
KitS
« Reply #32 on: February 15, 2025, 08:11:56 pm »
SUCCESS!  :-))
I sent the ECU back to Component Shop and asked them to have a look at it to see if I actually needed to replace it. They re-programmed it properly and it came back today.
I've put it all back in the Huntsman and it works a treat!  :-) :-))  Great work on the Shop's part.
We could be trialling the boat at Wicksteed Park tomorrow, if the weather's warm enough.
Kit
« Reply #33 on: February 16, 2025, 11:02:54 am »
Post photos!
KitS
« Reply #34 on: February 16, 2025, 03:16:31 pm »
Post photos!
Hehehe, I plan to, it'll be a momentous event for me.
The weather's too inclement for my partner so we're staying in the warm today.
Kit
ChrisF
« Reply #35 on: February 16, 2025, 03:34:04 pm »
Good news Kit.
Chris
KitS
« Reply #36 on: March 07, 2025, 03:23:34 pm »
We never did take the Huntsman to Wicksteed Park last week as the weather was far too chilly, but I trekked back home earlier this week and I've just tested the Huntsman out on Lydney Lake, and does she ever GO!  :-))
I was a trifle put out finding that the crazy transmitter had reversed the rudder control for some obscure reason, so sailing her took some SERIOUS thought, plus a couple of geese decided to investigate what the noisy foreigner was on THEIR water.
They decided they'd go and check on the other end of the lake once I opened the throttle though! The Huntsman doesn't hang about, running about 3-4 times as fast as it's going in this pic, and planes superbly, looking JUST like the real thing.
She took on a little water in the bilges and I'm not quite sure where it's coming in yet, but a floatation test in the bath may sort that out.
I'm a very happy bunny now.  :-)
Kit
« Reply #37 on: March 07, 2025, 03:31:49 pm »
Looking good Kit, it's nice to se it on the water again.
It is possible you might be getting a bit of water up the prop tube. Check that there is only a tiny amount of play in he shaft. I assume there is a thrust washer between the locknut and the end of the tube.
Another possibility is that when you slow down the following wave climbs up the transom and a few drops find their way over the low coaming along the back of the hull aperture.
KitS
« Reply #38 on: March 07, 2025, 03:38:06 pm »
I'll have a look there Colin, but the water was in two areas of the hull, separated by a bulkhead. One area could have been due to a prop shaft leak, but I'm not so sure about the other one.
Kit
« Reply #39 on: March 07, 2025, 03:39:26 pm »
See my edit above.Where was the second leak?
KitS
« Reply #40 on: March 07, 2025, 05:00:48 pm »
Yes, getting pooped can always be a problem with a fast boat. I didn't slow down fast enough for that, been had like that before, even in a full size boat!
The 2nd leak was in the battery/receiver bay, just aft of the motor bay.
Kit
« Reply #41 on: March 07, 2025, 05:45:27 pm »
In that case maybe the joint through the keel where the shaft passes through has opened up a bit causing seepage. When building this boat (and on the subsequent kit) the proptube was fitted after glassing over the hull so there could be a weak point maybe opened up by vibration. Dave epoxied the tube in.
 If the hull itself is leaking anywhere there should be some evidence of cracking on the outside.
KitS
« Reply #42 on: March 13, 2025, 02:40:32 pm »
False alarm on the 'leak' 'cos there isn't one.
I just held an extended session in the test tank (= bath..............) running the motor in forward and reverse, and not a drop to be seen. I reckon it must have been a sharp stop pooped it a bit, and I'll try and not to do that in future.
As it's forecasting snow here later  :((  test sailing at Wicksteed probably isn't a good idea, but we may give it a go there at the weekend.
Kit
ChrisF
« Reply #43 on: March 13, 2025, 02:49:06 pm »
Yes, because of the design of the bow and the narrowness of the hull the Huntsman 31 is the one Fairey that dips the most when coming off the throttle.
