Author Topic: Looking For A Suitable Transmitter  (Read 1988 times)
Pat-K
« on: February 13, 2025, 10:42:10 am »
Hi
My name is Pat I am from Southport in the UK, the place where all the murders were last summer :-
(I have just brought a Radiomaster TX16S and i have to say I am very disappointed with it so I am looking for something else. My main requirements are as follows:-
1. Must have a application to setup and maintain models on a PC.
2. I will be using only boat models.
3. Must have 16 Channels
4. Must be reasonably priced (£200-250 GBP)
5. Must be readily available
6. MUST NOT use Open.Edge Tx.
7. Must be readily available in the UK.
8. Must have joysticks for controlling rudders and speed - two speed sticks need for port and Stbd engine. and switches to switch other devices such as lights on and off
9. It would be nice if a multi protocol unit was available so I did not have to change all my receivers .
10. Storage if not internal must be on a reliable type of removeable media.
11. Ability to store around 25 models.
I know this may be a tall order but surly I am not the first person to request all theses features.
Would be grateful for your input
TiaPat
tsenecal
Re: Looking For A Suitable Transmitter
« Reply #1 on: February 14, 2025, 03:31:35 am »
Sadly, based on the list of requirements, there are zero radios made today that will meet all of them.
What brand receivers do you currently own?
There are NO radios made today that have two throttle sticks.
The only brand of radio i am aware of that will provide 16 channels, do not use OpenTX/EdgeTX, and are priced less than 250 gbp are a couple models made by FrSky, and use their own firmware called "Ethos".  They all support multi-protocol modules.
Frsky Twin x14
FrSky Twin X lite
FrSky Horus X10 express
Frsky Tandem X18
There may be others, but those are all i can think of right now that have Ethos firmware installed, and are below the 250 limit.  There is an "Ethos Suite" software package that only runs on windows, and it allows you to backup radio models, and update firmware for the radio.  it does not "simulate" the radio.   All ethos radios support 24 channels on 2.4ghz frsky receivers, and up to 16 channels on other receivers, depending on receiver, using the multi-protocol module.  FrSky does make less expensive radios, but they all run OpenTX.
In the "under 250" group, there is also the FlySky Paladin, i believe it supports 18 channels, but it does not support anything but their own flysky receivers, and it offers no companion like software.
There are multiple different transmitters well below your 250 limit, but they are missing lots of items from your list, ie, less than 16 channels, no pc software, only proprietary receivers, store 10 models, etc.
Other brands that support up to 24 channels include Futaba, Spektrum, Jeti, Graupner and a few others, but they are all much more than 250 gbp, and only Jeti has anything remotely like a companion, but it also does not support simulation, only backup of models, and updates of firmware for the radio.    All of these manufacturers also delineate their models by price AND functionality, so their lower cost models may not support 16 channels, but even then, we are talking models that cost 400 to 800 gbp
Fastfaz
« Reply #2 on: February 14, 2025, 08:06:06 am »
Hi Pat,
    Come along to Southport MBC Rotten row on Sunday (8.30/12) and have a chat with the members I'm sure one of us can help. From your list the two throttle sticks, am I right in thinking that you want to operate Tank steering i.e. left stick for Port motor right stick for Starboard motor? That is easy to set up, I use it on all my boats with twin motors, you need sprung self centering on both sticks not a ratchet on the left stick. Personally I use Spektrum radio gear I have a DS6i (can take 10 boats)and a DS6(can take 240 boats) both of which have sprung sticks. Hope this helps.
        Regards, Pete. :-)) :-))
JimG
« Reply #3 on: February 14, 2025, 11:53:19 am »
Jeti Studio does offer simulation, allowing the setup of the transmiter with the PC. However Jeti is way out of the pric range asked for, basically being aimed at the top end of model aircraft.
Jim
Dundee Model Boat club
« Reply #4 on: February 15, 2025, 10:44:12 am »
Must have a big toy room/Garage to be able to store 25 models.  O0
Page created in 1.009 seconds with 17 queries.
