Author Topic: Krick Victoria Blues  (Read 8778 times)
Rob1962
« on: March 11, 2025, 02:03:22 pm »
One of my Krick Victoria lay dormant for 8 years indoors and the engines runs perfect on the bench but the Drive shaft is frozen and the floors were glued down 0ver 15 years ago I inverted the model on it front and been adding penetrating oil for a week but still frozen in the brass tube which is only a half inch at each end,Spring is nearing here in New York City and would like to get it running.I already broke the 3 Bladed Propeller,I could really use some advise.
Thank you
Robert.
Proud owner Krick Victoria & Krick Borkum.Cheddar Claire/pintail E & B
1967Brutus
Re: Krick Victoria Blues
« Reply #1 on: March 14, 2025, 07:55:15 am »
It is a rough method, but...
Get a nut of the same thread size that is on the shaft (if the shaft is what came with the kit, that would be M4).
You will need some sturdy tubing, slightly larger ID than the shaft, but not so large that it will go over the sterntube.
Cut several pieces of that tubing, slightly shorter than the protruding part of the shaft, such that you can slip the piece of tubing over that end stump, and still place the nut with good purchase on the threads. 3 or 4 pieces should be enough.
Lubricate that tubing, the nut and the thread with some grease to prevent marring or fretting, and tighten the nut. That will pull the shaft backwards and it should not take too much effort breaking the shaft free by tightening the nut.
Add another piece of tubing if you reach the end of the thread, and the shaft is not free yet.
It is NOT sufficient to only make the shaft movable: there will be dirt, debris, corrosion and other crap in that tube, running it "as is" will very rapidly cause problems due to wear.
What is holding your shadt right now, is most likely corrosion between shaft and endbearings. These endbearings are only somewhere between 1/2 and 1" in length, so near 100% sure, once the shaft has been pulled more than that, at least it sould come loose.
Worst case you have to continue adding these pieces of tubing until the shaft is out all the way.
Once out, you can polish the shaft, carefully ream the bearings with a 4 mm drill bit, flush out the tube (WD40, brake cleaner, something like that, it is going to be messy :( ) and reassemble.
Removal of the tube from the hull will be a chore, but IF you manage, my advise is to buy a Raboesch mainenance free shaftset.
Those are BRILLIANT, 100% watertight and they are as advertised, absolutely maintenance free. A bi pricey, but these shafts will outlast you...
Rob1962
« Reply #2 on: April 14, 2025, 06:19:23 am »
Thank you Brutus for this possible solution it is a bit beyond my scope but if all else fails I will give it a got,The brass shaft has brass welded endocarps on both ends so im not too sure how to accomplish this possible solution.
I will update here of any progress.
Best Wishes.
1967Brutus
« Reply #3 on: April 18, 2025, 06:46:27 am »
It is way easier than you think. If you don't have the possibility to cut pieces of tubing, just buy a bag of washers. Has the same functionality.
I can assure you, the worst that COULD happen is needing a new shaft (if it is too corroded) because it won't be the brass that caused it. The tube will be OK.
